Old 10-23-2014, 12:09 PM   #1
Help, On trip NO power to Outlets / Microwave
So last night on my 2011 Sunseeker 2860 I had a small heater running off the outlet above the Sink, I was connected to line power @ my house, Not thinking I unplugged the line power from the house with the small heater running in the RV. This seems to blew a breaker so I thought, I figured when I got to my destination I would just reset it.
Well I'm here and it's not any of the breakers or fuses, and the GFI in the kitchen isn't tripped.. I get no power to the microwave, or any of the outlets.
When I fire up the generator I feel like it's not providing power and that I'm just running off DC power, The T.V. doesn't work either.. This is so weird, but I feel like it's something I'm missing..
Can anyone give me any insight?
synergist is offline   Reply With Quote
Old 10-23-2014, 12:14 PM   #2
TURBS's Avatar
Gfci in bathroom?
Turbs
Old 10-23-2014, 12:15 PM   #3
While none of the breakers look blown. I would start with manually resetting your main breaker. Also check the breaker on the generator.
jbrostek is offline   Reply With Quote
Old 10-23-2014, 12:19 PM   #4
I'm new to this, so please bear with me, I turn off ALL the breakers and lights and everything in the RV still work. I cycled all the breakers and still NO GO. Cycle but flipping them all to off, turning on the main and then enabling each one...
Generator had one breaker I could see, a 30AMP i Cycled that as well.
Old 10-23-2014, 12:20 PM   #5
TURBS's Avatar
Your lights are 12 v that's why they don't shut off.
They are running off your battery.
Turbs
Old 10-23-2014, 12:21 PM   #6
GFI is in fron of kitchen sink and is not tripped
Old 10-23-2014, 12:21 PM   #7
TURBS's Avatar
There's one in your bathroom as well.
All outlets are run by these gfci outlets.
There might even be a third in one of your outside compartments.
Turbs
Old 10-23-2014, 12:23 PM   #8
ernest917's Avatar
Do you have an inverter/converter???? Mine was off at one time and certain things wouldn't work...
ernest917 is online now   Reply With Quote
Old 10-23-2014, 12:23 PM   #9
Turbs
Just a regular plug that says GFCI protected.. No breakers or such on the plug to reset it.
Old 10-23-2014, 12:24 PM   #10
I'm assuming I do, I just don't know where it is....
Old 10-23-2014, 12:25 PM   #11
TURBS's Avatar
I'm thinking we need bclemens. .........
Turbs
Old 10-23-2014, 12:25 PM   #12
ernest917's Avatar
Under bed ?? Outside compartment ??
Old 10-23-2014, 12:26 PM   #13
TURBS's Avatar
I agree.
This unit surely has more then "one" gfci
Turbs
Old 10-23-2014, 12:27 PM   #14
ernest917's Avatar
What kind of rig do you have????
Old 10-23-2014, 12:28 PM   #15
TURBS's Avatar
Sunseeker
Turbs
Old 10-23-2014, 12:29 PM   #16
ernest917's Avatar
Check near your batteries.....
Old 10-23-2014, 12:36 PM   #17
I agree.
Turbs
Ok found the power converter, it was under bed, I pulled fuses, they look good and then I plug them back in, fans spins up and then it clicks off... I'm looking everywhere for another GFI..
Old 10-23-2014, 12:41 PM   #18
ernest917's Avatar
Ck in ur outside compartments....
Old 10-23-2014, 01:06 PM   #19
So I really think I smoked my inverter, the inverter 950W inverter, has 2 fuses, when I pull them and put them back in, the fan on the inverter spins up and then about 8 seconds later suddenly stops.. Given I have no 110 anywhere it has to be that.
I think I can live without 110 I was just worried that it would affect my ability to charge my batteries, as long as my batteries are charging I can power thru this.
I honestly want to thank all of you for helping... I'm just new and didn't want to get stranded...
Old 10-23-2014, 01:12 PM   #20
Kaadk's Avatar
Not sure if I missed it, but is this only on the generator or did you also plug back into the house?
No power from either than I'd be looking at possibly the transfer switch?
power, electrical
