Old 08-05-2013, 11:50 AM   #1
Question Help!! Speaker noise (humm) with outside flood lights on
Hello everyone!
I'm new to the FR forum, and appreciate all recommendations to help solve my speaker noise dilema. I own a 2010 FR Shockwave 29SALX with Clarion Stereo System with AMP (inside & outside speakers). While listening to the stereo with the (2) outside lights on, I hear a constant "buzz" or "humm" in the speakers. When I turn off the outside lights, the noise goes away and the speakers sound perfect. Possible ground? If so, where should I check for proper grounding? Also, does anyone have an electrical diagram of my FR Shockwave?
Thanks in advance for your replies.
Cheers!
Bob
gunner_bob is offline   Reply With Quote
Old 08-05-2013, 12:04 PM   #2
fmc
fmc's Avatar
I had a similar problem with a Vizio sound bar. I purchased a ground loop isolator for the speaker wires on eBay for about $8.00 and it solved the problem.
fmc is offline   Reply With Quote
Old 08-05-2013, 12:37 PM   #3
Smile Ground loop isolator location
Where did you hook up the ground loop isolator?
Old 08-05-2013, 01:19 PM   #4
fmc
fmc's Avatar
Mine uses RCA style plugs and it just plugs into the speaker wires on one side and then the speakers on the other.
light
