Old 07-15-2018, 10:25 PM   #21
HONDAMAN174's Avatar
I ran the wire down the drain tube and about 2inches from the end I cut a little hole at the TOP of the tube and sent the wire thru. Wired it just like you have it a long with three 120mm fans to aid air flow over the outside fins.
Just glad to get away
Old 07-19-2018, 11:09 PM   #22
Mch5jdm's Avatar
So dumb question... are fans for the inside of the fridge or back by the condenser?
Letís go camping!
Mch5jdm is offline   Reply With Quote
Old 07-20-2018, 12:07 AM   #23
jtesta1's Avatar
Inside
jtesta1 is offline   Reply With Quote
Old 07-20-2018, 07:33 AM   #24
Not a dumb question cause the answer is both. The fans talked about here are interior fans blowing on the cooling fins. Many of us also have external fans like large computer fans that assist even more.
I have 3 5Ē fans: one bringing in fresh air, and two at the top of the chimney sucking out hot air. So I have my unit on getting ready for weekend trip. On propane, in 106 temps, the freezer is -1 and fridge is 30. Also before I put in those fans the cabinet next to the fridge would get hot from the hot air and would melt candy and like items. Now the heat goes right out the top.
Old 07-20-2018, 10:29 PM   #25
Mch5jdm's Avatar
Okay. That makes sense. I like the inside fan idea. I noticed that when the fridge was fuller at the beginning of the trip it wasnít as cold but as it emptied out it was noticeable colder. I can see how food can actually insulate the temperate. A fan will help move air.
Letís go camping!
Old 07-21-2018, 12:48 AM   #26
jtesta1's Avatar
The fridge is cooled by heating ammonia. So by putting fans in the back of the fridge youare cooling the ammonia thus heating up your fridge. I let mine cool naturally and in this warm weather i have to turn my fridge down to keep everything from freezing.
Old 04-14-2019, 08:08 PM   #27
Overtime's Avatar
I have been looking at adding fans to my fridge to help out. Can someone post a link to the fans referenced in this post? Thank you in advance.
2019 Forest River Rockwood 2109S, following a 2010 Dodge Ram 1500 W/4.7L
Overtime is offline   Reply With Quote
Old 04-14-2019, 09:29 PM   #28
rk06382's Avatar
This is my Fridge fan install:
1> I replaced light with a LED light.
2> I installed a 0.15a Fan to the light switch.
75mm x 30mm 7530 12V Dual Ball Bearing DC Brushless Cooling Blower Fan from Amazon
Name:	Dometic Refrigerator DM2652 20181112_115849.jpg
Name:	Dometic Refrigerator DM2652 20181112_120002.jpg
Also check out my thread for more info:
Dometic RM2652 Thermistor Adjustment fix
Robert
2018 FR3 28DS
Samlex EVO-2212 Inverter/Charger| 400ah Battle Born LiFePO4 | Victron BMV-712 & MPPT 100/50 | 800W Renogy Solar | Fan-Tastic Fans | Blue Ox TruCenter | Dometic 320 | SnapPads |
My Samlex EVO-2212 Inverter/Charger install
rk06382 is offline   Reply With Quote
fan, refrigerator
