Minor problem, 2012 Lexington 283ts, keep blowing the 15 amp fuse everytime Heng's Range Hood fan motor is turned on. Checked wireing, but it's on the same wire circuit as range light and slide-out light, which all work without blowing fuse. Only turning on fan motor blows fuse.
Tried swapping the light switch with the fan switch, no change, light works, fan blows fuse, so it's not the switch.
Wondering if the motor is bad, and if anyone else has had the same problem.
New motor is only $20 bucks or so, and I'll probably replace it, but just thought I'd ask.
Grumpy
