Old 06-08-2013, 07:04 AM   #1
Home style refrigerator
Question for the electrical experts. Can a truck's alternator put enough charge into 2 deep cycle batteries to be able to run a regular home style refrigerator from an inverter? Just wondering.
Old 06-08-2013, 07:17 AM   #2
Dave_Monica's Avatar
Certainly no electrical expert but I think you'll need to provide a size so you'll know the watts it draws.
Dave
Old 06-08-2013, 07:26 AM   #3
Dave
Let's use 750w running and 1000w start up.
Old 06-08-2013, 07:29 AM   #4
I found some power consumption numbers...380W for a 16 cu ft fridge/freezer, 420W for 20 cu ft. This is probably running and as you say, starting draw would be higher.
Dave
Old 06-08-2013, 07:30 AM   #5
Lot of Refer.Posts today? Youroo!!
Old 06-08-2013, 07:39 AM   #6
I seen a mid 80s 1/2 cargo van being used as a ice cream truck with a full size freezer in it. The inverter was laying beside the freezer and it was the largest one I've seen...not that I've seen a lot if them.
Frankm2 is offline   Reply With Quote
Old 06-08-2013, 08:31 AM   #7
750 watts / 13v = 57.7 amps. I think alternators are about 55 amps normally but may be wrong. It sounds pretty iffy. For sure your truck won't charge your RV batteries to do it that way. There was another thread on this very topic last week I believe it was. You would need to put the inverter into the truck and run an "extension" cord from there to the refer. Just don't leave it running when the truck engine is off.
Edit: See this: Power inverter that runs the refrigerator
