Old 06-23-2015, 06:56 AM   #1
Honeywell RTHL111B thermostat replacement
Ok, I've done the "search" thing, looked at old post, reviewed old videos. I would love to have a simple diagram of where to put the six wires from the old thermostat to which terminals on the new honeywell. I will try to attach two photo's of the old wires. The new stat has: B O G Y W not used R/RC jumpered.
Hope the pic worked. I am always amazed at the knowledge base on this forum!
pdqparalegal1 is offline   Reply With Quote
Old 06-23-2015, 12:22 PM   #2
Crockett's Avatar
well this sort of thing might be done, but its not what is done on a regular basis. the honeywell is made for a 24 volt ac "household" style system while the rv either has a dometic or coleman ac. the coleman get 12v dc from the furnace while the dometic generates its own control power from the lower board on at least the earlier models.
Crockett is offline   Reply With Quote
Old 06-23-2015, 12:42 PM   #3
waiter21's Avatar
No photos???? Post some photos of the old wires and old connections and lets take a look.
I replaced mine, but it was for the furnace only and only used two wires.
Install new Digital furnace thermostat | 2001 Coachmen Mirada 300QB
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
Old 06-23-2015, 01:09 PM   #4
Will try to post photos again. I may need to research HOW to post pic's. I have the wires connected except 1, a red (splices to gray). Coleman had red wires labeled W1 (from heater), has power all the time, and the other red (gray ) w3 don't know where to put it in the Honeywell. However I put the gray wire the fan runs constantly, even on "auto". Seems with all wires put somewhere, fan on=high, fan auto = low speed. I'll try to post pic's
A/C and heat work, just can't control fan
Old 06-23-2015, 01:21 PM   #5
Will this help?
Old 06-23-2015, 01:29 PM   #6
one last time!!
Name:	20150623_125254(1) (640x360).jpg
Old 06-23-2015, 03:15 PM   #7
waiter21's Avatar
Did you take photos of the wires on the old thermostat? Thats what is needed.
Old 06-23-2015, 04:30 PM   #8
Did take photos, been trying to send them from my phone to computer so I can add tp post. News! With all "EXCEPT" red/gray wire hooked to new thermostat all seems to work. Fan runs on High but will shut off when temp gets to preset. Evidently the r/g wire is low speed fan. I can live without if unless someone can tell me where to put that wire.
ID:	80878   Click image for larger version
Old 06-23-2015, 04:34 PM   #9
top photo old thermostat= l to r
red,yellow, white,gray, green, blue
bottom photo, new thermostat, Honeywell= l to r
blue, blank, green, yellow, white, red, did not use gray
any offers as how to do differently?
Thanks to all who offered suggestions.
Old 06-23-2015, 10:17 PM   #10
waiter21's Avatar
I googled "ICM controls" and found a thermostat that looks similar.
This is the link to the manual that may help you figure out wire connections.
http://www.icmcontrols.com/ProdImages/ig_LIAF013.pdf
replacement, thermostat
