Old 05-28-2016, 07:16 AM   #1
tdidad's Avatar
Hood fan 8289WS
Does anyone have a hood fan that appears to intake air rather than exhaust as it should. I had my dealer check it out and he states that it is functioning normally. When I go outside and unlock the side damper and my wife turns on the fan the damper is sucked back into the closed position. I didn't want to alter any wiring seeing that it is still under warranty but once again questionable QC.
Ď17 Rockwood Signature 8328BS
tdidad is offline   Reply With Quote
Old 05-28-2016, 07:52 AM   #2
Don't Camp Enough
DSMURPHY's Avatar
NEVER had a hood fan pull air. Get the dealer to check it again and prove to you that it is working properly.
Good luck.
'2016 Rockwood 8288WSA
'2010 Tundra
DSMURPHY is offline   Reply With Quote
Old 05-28-2016, 08:08 AM   #3
Pickin' & Campin'
Open the flapper, go inside and turn on the hood fan, light a match and blow it out and hold it near the intake... see which way the smoke goes. You'll know in an instant if it is working correctly.
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 05-28-2016, 09:20 AM   #4
I dropped my microwave down and turned the motor around so it would blow air out. It's easy to do. Most microwave fans come blowing in instead of out
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is online now   Reply With Quote
Old 05-28-2016, 10:24 AM   #5
Hood fan, not microwave fan.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - Tow Package
boondocking is offline   Reply With Quote
Old 05-28-2016, 10:27 AM   #6
B and B's Avatar
Polarity is backwards on the motor. Just swap the leads on the motor.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 06-18-2016, 04:05 PM   #7
tdidad's Avatar
Yep that was it. Was wired incorrectly from the factory, took your advice and all is working well, thank you!
Old 11-02-2016, 10:48 AM   #8
I have a microwave that vents back into the living space, a factory install by Cedar Creek. I would like to vent it outside but I'm not sure how to do it. The oven is pretty tight against the rear of the cabinet and I believe the exterior wall of the RV is not very thick so I need some guidance on how to connect an exterior vent louver to the microwave. Has anyone done this? The way the microwave works now nothing gets vented to outdoors which is silly since we have the normal propane stove/oven below it and numerous warning stickers about dangers of carbon monoxide on the surrounding cabinet. Thank you!
Cedar Creek 36CKTS
Bemo is offline   Reply With Quote
Old 11-02-2016, 05:50 PM   #9
Believe it or not my Cedar Creek came with a outside vent but the microwave blew exhaust air into camper. I dropped the microwave and turned the motors around. You may can drop the microwave and you may have a X marks the spot to install a vent in. If not you can measure where the vent goes at and drill one. I cut a hole in my Cedar Creek to install a washer/dryer, I cut a stud out but the way Cedar Creek glues everything up that wasn't a problem
Old 11-02-2016, 07:17 PM   #10
I understand what you mean but how would I ever seal/connect the exterior louvre to the rear of the microwave? Any idea? Thanks very much!
Cedar Creek 36CKTS
fan
