Old 03-31-2019, 11:05 AM   #1
rmac04401's Avatar
Hooking up rear view camera
I am hooking up my rear view camera that came off my old trailer. The running light wires on the new camper one is white and one is white with yellow line on it. Does anyone know which is positive and which is negative. I donít want to burn up my camera. Click image for larger version
ID:	200332Click image for larger version
This is where Iím going to mount my furion camera between the two running lights.
2019 Puma XLE 27QBC Toy Hauler
2005 Honda VTX 1300
2012 Ram 2500 Crew cab 6.5 bed
5.7L Hemi, 3:73 Rear
Ron & Shirley (Empty Nesters)
rmac04401 is online now   Reply With Quote
Old 03-31-2019, 12:53 PM   #2
rmac04401's Avatar
Found my multimeter. I am all set now. Thanks.
2005 Honda VTX 1300
Old 04-01-2019, 05:59 PM   #3
Which was which? I'm about to install a camera, myself.
Thanks!
TraderPat is offline   Reply With Quote
Old 04-01-2019, 08:20 PM   #4
rmac04401's Avatar
Thanks!
I will post pics on Saturday. I spent the rest of the day checking out good location. Waited till dark to see how running light effected the position of camera.
Today it cooled back down, so did not hook it up. I will post everything when Iím done.
2005 Honda VTX 1300
Old 04-02-2019, 12:27 PM   #5
DustyRoads's Avatar
Thanks!
Use a volt meeter to check. If the voltage appears positive then you have the positive probe on the correct wire and you should be good. If it shows a negative number switch the probes and it should then show positive.
2017 Forest River Surveyor 251rks
2016 Chevy 2500HD
DustyRoads is offline   Reply With Quote
Old 04-02-2019, 12:51 PM   #6
I've been told by a couple of RV techs that RV makers don't usually color code their wires...they use whatever they have on hand. A circuit or multi tester is the only way to be sure.
DrLewie
Flemington, NJ
Former: 2007 Cardinal 30W LE
Now:2018 Arctic Fox 27-5L
2008 Ford F-250 Long Bed Diesel
Total of 25 Months on the Road Since 2008
DrLewie is offline   Reply With Quote
Old 04-02-2019, 03:13 PM   #7
I used a pickup truck tool box mount to get the camera out a bit farther. It was done to get a better down angle view. It worked perfectly to conceal the wires as-well.
ID:	200566   Click image for larger version
ID:	200567   Click image for larger version
ID:	200568   Click image for larger version
PenJoe is offline   Reply With Quote
Old 04-02-2019, 08:37 PM   #8
You can do that...
Doc, you can do that for incandescent lamp marker lights, but LED marker lights must be wired with correct polarity.
Larry
Larry-NC is offline   Reply With Quote
Old 04-03-2019, 08:13 PM   #9
rmac04401's Avatar
The wire with yellow stripe was the positive wire. The job is done now. Here are some pics.
ID:	200691Click image for larger version
ID:	200692Click image for larger version
Before anyone says something about it being above the running lights. I tested it there at night. The camera is not a night camera so the lights do not effect. Actually when I turn on the deck light you can see whatís back there. Besides there was no room to put below the lights.
All in all turned out good. Canít tell it was not done by factory
2005 Honda VTX 1300
Old 04-04-2019, 06:23 PM   #10
rmac04401's Avatar
Daylight picClick image for larger version
ID:	200766Click image for larger version
2005 Honda VTX 1300
