Hooking up satellite antenna
I have a 2018 Forest River Forester 3011DS , 32’ Class C MH.
I want to know how to best hook up a satellite antenna, and once connected, will it be viewable on all TVs, or just the main living area TV?
Above my entertainment center are two coax faceplates. In the lower compartment is the one that has a coax attached to it that I assume is where the rooftop digital antenna signal comes in, and the coax goes to a splitter, enabling me to get a signal on all TVs. It has the little green light that I understand is a signal amplifier indicator, and I have clicked it off to use Campground cable attached to the coax connector on the side of my rig, near the shore power connector. I am all fine and good with that.
Then comes the mystery coax faceplate in the upper compartment with an HDMI female plug integrated into the face plate. Is this connected to the outside connector on the side, or another connector up top? The HDMI Plug does not seem to be attached to the TV in the living area . . . Should it?
I have played around with a connector to my iPhone, plugging it in to an HDMI PORT of the TV with an adapter, then using the “source” button on the remote, I am able to stream stuff over iPhone to TV. I am all fine and good with that.
But, when plugging into the HDMI Port on the upper coax faceplate, I cannot find a signal coming through to any TV Port. Should I be able to?
Is there a rooftop connection to the coax wall plate inside?
Where can I hook the sat dish and Wally receiver up to get the signal to the TV(s)?
