Old 05-31-2016, 11:04 PM   #11
Dr-G's Avatar
Great thanks for the advice. I assumed you would need them both on, but it stated to turn of the gas... So I assume they are just doing a step-by-step for switching to electric only. You would need to turn off the gas but it sounded like you had to turn the gas off. I plan on using the propane just in case we get overloaded. Sounds like it may not even be an issue.
I have been checking the tank to be sure it is full. It's really hard to get a wrench on the drain plug, so it seems to leak a little. I cranked on it a bit more so we'll see if it stays dry overnight tonight. Not sure what size it is, but I don't have a socket that large.
'16 Cherokee Grey Wolf 26DBH
'13 Silverado 2500 HD - 6.0 Vortec / 3.73
Days Camped '16 - 12
Days Camped '17 - 0
Dr-G is offline   Reply With Quote
Old 05-31-2016, 11:24 PM   #12
Drain plug is 1-1/16". If it's leaking, I would suggest you remove it and re-install it using some teflon plumbers tape on the threads.
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 05-31-2016, 11:38 PM   #13
Dr-G's Avatar
I took the old teflon tape off and put new on. I just could not get enough purchase on the plug with the wrench. 1 1/16th socket is what I need. Thanks!
Days Camped '17 - 0
heater, hot water, water, water heater
