Old 01-28-2019, 02:47 PM   #1
hot water heater
How many people use the electrical function?
Bluetick1955 is offline   Reply With Quote
Old 01-28-2019, 02:59 PM   #2
Grammar Pedant
67L48's Avatar
Every time I'm connected to power, I use the electric function on my water heater (I've got the super cool version that heats all types of water ... not just hot water). I figure that I already paid for electricity and don't need to use my own propane to heat the water.
Once, I pulled into camp and wanted hot water within about an hour of setting up camp. I used both to speed the heating process up. But, I turned the propane off after that.
Good luck.
Current RV: 2018 Rockwood Mini Lite 2504S
TV: 2005 F-150 King Ranch 4WD SCrew 5.4L Tow Package
Ordered TV (May): 2019 F-350 Lariat 4WD CCSB 6.7 PSD 3.55
67L48 is offline   Reply With Quote
Old 01-28-2019, 03:04 PM   #3
2007 WildCat 32QBBS
05CrewDually's Avatar
Good luck.
Same, same, & same.
05CrewDually is offline   Reply With Quote
Old 01-28-2019, 03:13 PM   #4
Multi-Slacker
It's just water heater. Putting the "hot" in front is redundantly extra and raises the question of why you would pay to heat water that is already hot.
2017 Forest River Sonoma 280RKS
2018 Silverado 2500 HD 6.0L, 4:10 rear
Prodigy P3 Brake Controller
Andersen WDH / Class V (2000 lb) Receiver
CurtPutnam is offline   Reply With Quote
Old 01-28-2019, 03:14 PM   #5
Good luck.
Same as well
2rad4u is offline   Reply With Quote
Old 01-28-2019, 03:20 PM   #6
bikendan's Avatar
I would think that anyone, who has shore power, would use the electric side over the propane side.
Can you elaborate on why you're asking?
Equalizer WDH
Old 01-28-2019, 03:24 PM   #7
Semperfi24's Avatar
If my electric worked I would use that. At present, its propane only for me. Got tired of swapping out parts and cant figure out what is causing the electric to fail. Worked perfectly fine for a year. Then out of nowhere both gas and electric stopped working. No hot water, period. Changed the module board and that fixed the gas, still no electric. Had extra parts so I just started swapping out things to see if anything worked. Changed the element, changed the thermostat, changed the switch (on the water heater), none of that worked. Then finally changed the relay and that fixed the electric side of the water heater...for 2 days. At that point I was done with it. I'd rather keep my sanity and pay for propane. At some point I will have a mobile tech come and check it out.
_________________________
2018 Ford F150 Lariat Special Edition 3.5 Ecoboost
Semperfi24 is offline   Reply With Quote
Old 01-28-2019, 03:28 PM   #8
D W
D W's Avatar
If electric is available I use it. If I need faster recovery I will use a combination of propane & electric, but only for recovery. I don't have to "refill" the electricity, but I do have to "refill" the propane.
'04 K3500 Silverado LS with LS3 Connect & Cruise- with Intimidator Mods- Reprogrammed 4L80E
2016 Salem 27RKSS (Pacific Northwest Build)
D W is online now   Reply With Quote
Old 01-28-2019, 03:37 PM   #9
Indy500's Avatar
Good luck.
What's the super cool one? And is there different types of water.
Indy500 is offline   Reply With Quote
Old 01-28-2019, 03:38 PM   #10
RV There Yet?
IsleDog's Avatar
this is how i run mine. Gas and electric right away to get it hot fast (my wife likes hot water right away and we dont travel with any). then electric until we want to shower, then both for the recovery. then gas off when done.
2018 17RP
2009 Crew Cab King Ranch F150 "Goose"
IsleDog is offline   Reply With Quote
heater, hot water, water, water heater
