Old 06-09-2014, 07:22 PM   #1
hot water heater
I have a 2012 forest river forrester my hot water heater is not working on gas, no power to switch on control panel is there a fuse I'm not seeing.
timbanker is offline   Reply With Quote
Old 06-09-2014, 07:43 PM   #2
RSchleder's Avatar
Most hot water heaters in RV's have one or two reset buttons on them. These buttons are typically under a rubber cover designed to keep water out. They are a bit hard to see unless you are specifically looking for it/them. I'd take a look there first. Good luck!
PS- you'll need to remove the exterior panel to see the section of the heater with the reset buttons on it.
RSchleder is offline   Reply With Quote
Old 06-09-2014, 07:45 PM   #3
TURBS's Avatar
Working on electric?
Fuse would be in the electrical distribution panel.
TURBS
"Sabre owners united"
heater, hot water, water, water heater
