Old 06-28-2019, 09:03 AM   #1
hot water heater identify
Hello,
I have a 2011 villa 42
My hot water has a sulfur smell to it. i have flushed the hot water heater. can someone tell me what kind of hot water heater this is. i know its 20gallon electric. but can you identiy the model and make?
Does this heater have a anode rod? i cant find one.
after flushing the hot water tank, i still get the smell. no one else at the campground has this issue. the camper is at same place for six months.
I have attached a pic of the heater
Thanks in advance
Dave
davidwjacob is offline   Reply With Quote
Old 06-28-2019, 09:04 AM   #2
here is attachment
Old 06-28-2019, 09:07 AM   #3
Mr. Dan's Avatar
Originally Posted by davidwjacob View Post
Hello,
Thanks in advance
Dave
Tell us which Forest River division makes the 2011 villa 42.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 86; booked = 0
Old 06-28-2019, 09:08 AM   #4
That is a small residential style water heater.
Hard to say who makes it.
It probably has an anode rod that goes in from the top.
It may be under a removable plate or the top cover itself but it is probably under that center plug on the top.
You likely won't remove it with the heater being back inside that cubby.
Days Camped: '16=46 '17=30 '18=51 '19=53
Old 06-28-2019, 09:08 AM   #5
wmtire's Avatar
The Villa has a residential (not RV) type water heater. Hold on and I will get you some links
2011 Flagstaff 831 RLBSS
Words are powerful.
Choose them good.
Old 06-28-2019, 09:11 AM   #6
ok thank you
its rusting on the bottom also, i think i might be replacing it
Old 06-28-2019, 10:01 AM   #7
wmtire's Avatar
We keep 5 videos from Suburban on their water heaters. Although this is not what you have, it does identify the source and cure of the sulfur/rotten egg smell.
Suburban Water Heater Video Guides
This video may help:
Words are powerful.
Choose them good.
Old 06-28-2019, 01:13 PM   #8
rlh1957's Avatar
Anode rod may be hidden behind one of the panels. If this heater is older than 5 or 6 years unless you plan to fix it yourself it will be cheaper to get a newer more efficient HW heater. All water heaters should be flushed out once a year, two at the most to remove sediment. RV'rs do it every year we winterize.
2018 Forest River Rockwood Roo
24WS
2019 Ford SD F-350 SRW Lariat
Tow & Gooseneck Prep
FX4 Off Road (4X4)
rlh1957 is offline   Reply With Quote
Old 06-28-2019, 05:01 PM   #9
Since this is a residential style heater I'm going to guess the anode rod comes out the top. They do make an anode rod that looks like sausage links. In Texas our heaters are in the attic and sometimes close to the sloped edge.
DYNAMAX 2016 FORCE HD
houstonstroker is offline   Reply With Quote
Old 06-28-2019, 05:35 PM   #10
bedubya's Avatar
I would replace it. Here in Des Moines, Home Depot has a 20 gallon electric water heater in stock. You'll want to measure your height and diameter, as well as inlet/outlet location.
https://www.homedepot.com/p/Rheem-Pe...20U0/204318374
'17 Toyota Tacoma 4x4 TRD Sport
'17 Salem Cruise Lite 232RBXL
'08 Kawasaki Vulcan Classic 1500
Mickey the Rescue Project Schnauzer
Days Camped: 2017-39, 2018-61, 2019-64
bedubya is offline   Reply With Quote
heater, hot water, water, water heater
