Old 03-26-2016, 08:38 PM   #1
Hot water heater problem
my suburban sw6de in my 5 only heats a few seconds then shuts down both on elec and on gas. I changed the outside switch (110v) but it still shuts down too soon. I tried reset buttons but that didn't help. 6 gal tank is full. There is no power to the heating element on 110v. I have checked bypass valve and it is closed. I suspect bad thermostat? Any ideas.
aviator42 is offline   Reply With Quote
Old 03-26-2016, 11:02 PM   #2
Too Tall's Avatar
It will recover faster if you turn on the propane heat and electric both.
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
Too Tall is offline   Reply With Quote
Old 03-27-2016, 11:31 AM   #3
I tried having both gas and elec turned on. It still heats only a few seconds then shuts down. It's not even long enough to get the water warm. That is why I'm suspicious of the thermostat because it controls both gas and elec sides of the equation.
Old 03-29-2016, 07:03 PM   #4
Head Rambler
According to the service manual for the sw6de there is nothing electrically common between the gas and electric sides. The gas side has it's own thermostat and the electric it's own.
How are you determining that the water isn't already hot?
Gotta go campin!
Old 03-29-2016, 08:05 PM   #5
hot water
I checked for hot water at the bathroom sink and the pop off valve. Neither electric side or gas side produced hot water; Just Luke warm at best to the feel over my outstretched fingers. And that is coming from the gas burner. The electric side is now shut off.
Thank you for the info on there being two thermostats for gas and elec. I'm thinking of changing both of them. I've already changed the electric outside switch. I'm docking in the driveway here at 6550 foot elevation (Edgewood NM) so that might account for the gas not working right. I will be heading for Missouri so will wait to see what happens at a 350 foot elevation before I tackle the orifice.
If I change enough stuff ... something's bound to work and I will know how and what to do if I ever run on to this sort of thing again. It's still cheaper than taking it to a dealer and waiting to get it back.
I will post my results so others can learn from my success ... or failure ... whichever the case may be.
Old 03-30-2016, 06:42 PM   #6
Safety on the temp side bad?
Kuba is offline   Reply With Quote
Old 03-30-2016, 07:02 PM   #7
Georgia Frog Rally 2018
aceinspp's Avatar
I would check to see if your water heater in line vales are turned correctly for summer use. They may be in the winterized position. You mentioned you had some hot water for a short time so this would be a good indication. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
Old 03-30-2016, 07:35 PM   #8
MarkyB's Avatar
The bypass valve on my new trailer was open when we got it. We had similar symptoms.
Wouldn't hurt to check.
16 F-250 Lariat 6.2 -- 16 Wildwood 31KQBTS
Nights Camped in 2016 : 25
Nights Camped in 2017 : 20
MarkyB is offline   Reply With Quote
Old 03-30-2016, 08:21 PM   #9
hot water problem
MarkyB may be right. I just checked and the by-pass valve was open. I just closed it and we will see? Thanks for the info and I will keep you informed.
Old 03-30-2016, 08:25 PM   #10
We have hot water. I think MarkyB may have found my problem. I'll know after I take a shower. Thank you.
hot water, water heater, water, heater
