Old 01-11-2011, 06:36 PM   #1
miatared's Avatar
Question How difficult is it to remove a ZX75...
I need to remove my ZX75 to have it replaced on my 2011 Shamrock 19, instead of taking the whole trailer, my dealer suggested I take it out and bring it to them - they will simply order a new one and swap it with me. I do not mind doing it - as I 'll have a chance to see the connections at the back at the same time.
Is is something like just a press-fit, do I need to pry off a bezel first or what ?
Thanks.
Denis & Diane
2010 Sabre 31REDS
Ford F-250 2011
* Happy Campers *
miatared is offline   Reply With Quote
Old 01-11-2011, 06:54 PM   #2
Iggy's Avatar
Thanks.
If it is like mine all you need to do is use a plat tipped screwdriver and pop off the outer ring. Under that you will find I believe 4 or 6 screws that mount it to the wall. When it comes off the wall all you need to do is unplug the plugs and antenna.
Hope this helps
Iggy is online now   Reply With Quote
Old 01-11-2011, 07:06 PM   #3
jk510's Avatar
As Iggy said it is very easy. The ZX75 has a bezel that runs down each side.
I use a phlat head screw driver and pop them off. Underneath you will find 3 holes on each side. There is probably a drywall screw in each hole that uses a #2 phillips screw driver, there was in mine. Be careful when you unscrew them because the head is actually a little too big for the hole and can bind.
Joel
Joel K
Southeast AZ
2013 Coachman Mirada 29DSSE
jk510 is offline   Reply With Quote
Old 01-12-2011, 03:28 AM   #4
cardinal4fun's Avatar
I would also add,
Mark each wire you unplug from the old unit. It will make installing new one easier.
3500 Ram 5.9l diesel
08 35 RLT Cardinal
5th Airborne Pin Box
cardinal4fun is offline   Reply With Quote
Old 01-12-2011, 08:28 AM   #5
Owner - RVtronics
Bob Fields's Avatar
Send a message via AIM to Bob Fields Send a message via Skype™ to Bob Fields
If they are replacing it with a ZX75 then you should be able to just unplug the main harness as well.
Depending on what was happening with the unit, you may need to double check the connections.
Bob Fields
bob@rvtronics.com
www.rvtronics.com
(781) 281-9440
Bob Fields is offline   Reply With Quote
Old 01-12-2011, 10:46 AM   #6
BOBFIDY's Avatar
Would a FLAT head screwdriver work too?
Had to add something...LOLOL
2011 FORD F350 CREW CAB DUALLY DIESEL 4x2
2010 Salem LA 292FKDS
One of the Original 14 F.R.O.G.s
1st, 2nd, and 3rd INTERNATIONAL F.R.O.G. RALLY Branson. MO.
1st, 2nd, and 4th INTERNATIONAL RALLY Goshen, IN.
BOBFIDY is offline   Reply With Quote
Old 01-12-2011, 11:42 AM   #7
I can take apart 90% of my trailer with a #2 square drive bit! Oh,I had a Flat head Ford one time! Youroo!!
youroo is online now   Reply With Quote
Old 01-12-2011, 01:29 PM   #8
miatared's Avatar
Talking
Thank you all - got it.
Now I just need to buy one of those new 'phlat' blade screwdriver set - love new tools.
Denis & Diane
2010 Sabre 31REDS
Ford F-250 2011
* Happy Campers *
