07-21-2017, 07:14 PM
How do I turn off the furnace fan? It's 90 degrees out and the blower won't stop
Furnace blower won't shut off and it's 90 degrees out
07-21-2017, 07:45 PM
We are going to need a little more info. What model RV? What thermostat? Are you sure it is the furnace fan and not the AC fan? Is AC on?
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
07-21-2017, 08:09 PM
2017 2104s. You can hear it as you walk in the door,it's a furnace vent located next to the breaker box close to the floor. Everything seems to be turned off.
07-21-2017, 08:16 PM
It might be the converter fan that is running .
Fonzie
07-21-2017, 08:22 PM
X2, the converter fan will run with most loads.
Turn your furnace on, you will hear the difference.
2015 F-250 FX4
07-21-2017, 08:25 PM
I have no idea what a converter fan is! Lol
07-21-2017, 08:32 PM
Get your manual out and read it, the manual will tell you were the converter is and what it does.
Not Camping enough Need therapy
2013 Forest River Salem/Sport Fifth WHL
2017 GMC Sierra 2500 Duramax/Allison
Curt Q20 Fifth wheel, Champion Inverter3500
US Army Retired
07-21-2017, 08:34 PM
A converter takes 110v AC input and produces 12v DC to run MANY things in an RV. It is generally situated behind the breaker/fuse panel. When there is a 12v load, the converter comes on. It has a cooling fan which runs when it's working. If the fan noise you hear is near the breaker box, you're most likely hearing the converter fan which was the answer in the 1st thread where you posted your question.
07-25-2017, 06:18 AM
Check thermostat fan setting make sure it's in auto.
2014 XLR Thunderbolt 380
2015 Sport Chassis
2017 Can Am Spyder
07-25-2017, 06:39 AM
You're trying to solve a different issue - that of the A/C blower running during furnace operation. This OP is hearing the converter fan running when nothing is on.
07-25-2017, 07:10 AM
If you sure it is the furnace after checking multiple vents then I'd pull the fuse as a last resort. We had a similar experience where the A/C and furnace were running together when I only wanted the furnace. Pulled the fuse for the A/C. Next time I went to use it after returning the fuse all was right again.
I put this one down as thermostats can have brain farts as well I guess.
Nights camped
2007 Shamrock F19 hybrid - 2010 (22 nights), 2011 (24 nights), 2012 (11 nights)
2013 Surveyor Select 235RKS - 2012 (6 nights), 2013 (32 nights), 2014 (26 nights), 2015 (37 nights), 2016 (14 nights)
07-25-2017, 07:27 AM
If the RV has been sitting for a week or more without being plugged in or the battery cutoff switch not turned off, you have drained the battery very low. When you plug in the converter will charge the battery at a high current level and that will heat up the converter and cause the auto fan to kick in. Try leaving the unit plugged in for a half to full day and check for the fan noise again. The fan will also run if you operate a lot of high current 12V appliances.
TST Tire Monitors
2 100W solar panels
07-25-2017, 07:56 AM
How loud is the fan? If it sounds like a jet airplane is landing in your RV, it is the furnace. If the fan noise is barely noticeable, it is the power converter. If it is the power converter, don't worry about it for now, it is doing what is is supposed to do. That fan will run most of the time that you are plugged in and have lights, refrigerator, etc. turned on.
Like others have said, take the time to read your manual. It doesn't help to only read them when you have problems. The manuals will save your bacon (in some cases -
literally).
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2016 Ram 3500 Laramie 4X4 6.7 Cummins Diesel
Never Enough Time Camping!!
07-25-2017, 08:09 AM
Problem solved!
Thanks for all of the help,it turns out it was the converter fan I was hearing.
07-25-2017, 08:15 AM
Curt, thanks for returning and posting the resolution. In the future other members may experience the same issue and this thread will be their problem-solver.
