The wall plate for the over the air antenna is also the connection area for cable. If you pull the wall plate off you will see two cables attached to the rear of the plate, one antenna other cable. You should have two coax cables one for the front and one for the rear tvs. You will need a spliter to get a signal to both tvs off the connection wall plate. To receive a good cable signal you will have to turn off the "power boost" button for the antenna, this will be a small button on the wall plate.
Now for satellite, if your unit has a seperate satellite hook up outside the inside cable will not be through the tv antenna wall plate. You will have to hook the cable to your sat. receiver and the tvs to the correct connection on the rear of the sat. receiver. I have dish network, my coax from the dish goes to the receiver then I hoodk my front and rear tvs to the correct connection on the back of the receiver.
3500 Ram 5.9l diesel
08 35 RLT Cardinal
5th Airborne Pin Box
