Old 06-04-2013, 09:17 PM   #1
prayers1's Avatar
How do you mount a lcd TV overhead
I have an older 1998 Forest River Georgetown Motorhome that has the tube tv mounted overhead up above and inbetween the driver and passenger within a cabinet made for the TV.
I would like to mount a LCD TV a little wider than the cabinet box. It will of course be mounted flat against the outside of the cabinet.
Any ideals ???????
Thank you!
prayers1 is offline   Reply With Quote
Old 06-05-2013, 02:24 PM   #2
Old Enough to Know Better
gasman6674's Avatar
When I owned my 94 class c I removed the analog tv and replaced it with a flat screen. I used a Sony that was the correct size (in my case a 22") and set it on the platform the old unit mounted on. Then drilled holes in the base to put deck screws into the platform. I also put sticky foam on the inside of the frame so the unit wouldnt rub plastic to wood. Worked well for two years. I now have the tv mounted on the bedroom wall of my current trailer. I also mounted a computer behind the flat screen so we could watch movies.
Name:	Entertainment Update 2 .jpg
ID:	32283   Click image for larger version
Name:	Entertainment Update 3 .jpg
ID:	32284   Click image for larger version
Name:	Entertainment Update 4 .jpg
ID:	32285   Click image for larger version
Name:	MO PIT TV CENTER.jpg
Jim & Debbie England
Do you have Gas? 2015 F350 6.2L CCLB DRW 4.30 axle. 2012 Yellowstone Ridgeline 34RLT Fifth Wheel
gasman6674 is offline   Reply With Quote
Old 06-05-2013, 06:19 PM   #3
prayers1's Avatar
That was a nice ideal and the pictures were great for the visual look.
I want to get a TV wider than the case and mount it outside and against the cabinet.
Anyone with any other ideals??
