Old 06-23-2016, 04:59 PM   #21
We have had some failey un level spots while traveling and our frige never stoped cooling.
NorSnrub is offline   Reply With Quote
Old 06-23-2016, 05:01 PM   #22
RedLdr1's Avatar
Originally Posted by MBSNewbie View Post
Why did you sell yours?
Too many issues with the M-B DEF system. It got to the point I didn't believe it was a reliable vehicle. For the trips we have planned that wasn't acceptable...
Wayne and Christine
2019 Sunseeker 2500TSF Pending Delivery...
2018 Ford Focus SEL Hatchback TOAD
RedLdr1 is offline   Reply With Quote
Old 06-23-2016, 05:19 PM   #23
Ford Idaho's Avatar
I bought one of these.
Prime Prodct 280201 Bubble Level, White - Walmart.com
Place it in the bottom of the fridge and center the bubble till it is inside of the circle.
Old 06-23-2016, 07:26 PM   #24
....or....
If you have an android phone, go to the app store and get the FREE compass level
2012 Ecoboost Screw, 3.31 (yes....really) rear end.
2016 Flagstaff 26FKWS, about 7500 loaded
Retired AF Mustang.....Picker always looking to jam.
Major Oz is offline   Reply With Quote
Old 06-23-2016, 07:29 PM   #25
Don't level it....then come back and let us know if its important or not...
Bob Montgomery is offline   Reply With Quote
Old 06-24-2016, 01:30 AM   #26
more important then the fridge, water intrusion when it rains. my slide is on the drivers side, if I don't have passenger side up a little bit, the water follows the rails into the camper. oh the joys of the pacific northwest....
poorbuthappy is offline   Reply With Quote
Old 06-24-2016, 06:52 AM   #27
DouglasReid's Avatar
Not much trouble to level
I have what is, for me at least, an easy way to level my 5th wheel. I have three 2x6 boards, cut at an angle that stack on one another. The shortest is long enough to fit under both wheels on a side at one time. Each board lifts the side 1 1/2".
After backing into a spot and looking at the front level I can tell how much I need to lift the lowest side. I simply back about 5' past where I want to end up, put the boards in front of the tires and drive forward onto the board(s) to get the level I need.
The boards stow easily in my pass through. Yes, I could spend around $3000 for a self leveling system but this works just about as well with just a small amount of effort.
Fore and aft leveling is accomplished with the landing gear and a level mounted on the side visible as I operate the landing gear switch.
2012 Wildcat Sterling 32RL, Maxxis 8008s Load rating E, TST 507 TPMS w/ Flow-thru Sensors & Repeater, Reese Sidewinder 16K Pin Box
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Futomo Oil Drain Valve, Turbo Brake activated in Idaho Rob Heavy Tow Tune, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
Old 06-25-2016, 09:29 AM   #28
FWIW somebody needs to do some math. For a 20 ft wheel base 3 deg is ~1 foot off level. You will be more unhappy than the refrigerator. That is why levelers on a C are an expensive toy in both cost and weight capacity.
I carry a couple of the stacked plank blocks but seldom need them. Most places a bit of wiggle in the parking spot is more than adequate.
nothermark is offline   Reply With Quote
Old 06-25-2016, 11:16 AM   #29
SeaDog's Avatar
Actually I believe it would be six inches at either end. Norcold wrote the manual and it is within three degrees one way and six the other. so using your math or mine you can be less then perfect and the fridge should work fine.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
fridge
