Old 06-23-2016, 08:25 AM   #1
How important is level on two way fridge?
Please be kind - we are newbies and have never owned a RV before.
I know this RV has stabilizing jacks but not leveling jacks. We want to be as mobile as possible and be able to come and go quickly from campsites or wherever we are to use the vehicle to go shopping, go out to dinner, etc. We don't plan on "setting up camp" for several days with this RV. Basically use it as a car and a camper. That's why we chose the smaller 24 ft Forester 2401W MBS RV. I've been reading and watching YouTube videos and this "leveling" an RV seems to be a pain with setting blocks, backup up over them, checking the level, adding or removing blocks, checking the level, etc. Is it as important as everyone is making out it to be? We are going to be constantly on the go, often only pulling into a park or campground late in the day and then heading out in the morning. I don't want to have to mess with trying to pull out blocks and backing back and forth for several minutes every day. I'm hearing that the fridge doesn't work unless you are completely level? What is the real experience anyone has had? I know this coach has a 2 way fridge but I don't know anything else. Obviously we need our fridge to work!
Thanks.
MBSNewbie is offline   Reply With Quote
Old 06-23-2016, 08:33 AM   #2
jeff64's Avatar
You can probably be off an inch one way or the other but remember whether its on electric or gas power it still operates off of heat by "boiling" the liquid ammonia compound. The variance from level affects how the liquid runs back down in the tubes. Sometimes, " dead nuts level" can be a pain to achieve, especially side to side. My DW says the level is off the blood is rushing to my head and I can't sleep, but I've known that for years!
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
Old 06-23-2016, 08:36 AM   #3
SeaDog's Avatar
It is important to be close to level when stationary I think my old Norcold called for 3* side to side and 6* front to back. So IMHO it is necessary to be close. If you take a little time to practice how many blocks it takes level given the amount of lean it will become very easy to get it right the first time without repeated tries.
Retired Navy
2016 Flagstaff 26 FKWS
Old 06-23-2016, 08:56 AM   #4
Pick a spot in your RV that you can trust to be level. I use the glass cover over the stove as my level spot. Place a bubble level there. If at least half of the bubble is within the marker ring, you will be fine. You might be able to get away with a little more than 1/2 bubble but it certainly would be problematic if there isn't much bubble within the marker ring. $.02
2016 Microlite 21DS
2014 Ram 1500 QC 6 cyl. 8 spd.
Blue Ox SwayPro
windsurfdog is offline   Reply With Quote
Old 06-23-2016, 08:58 AM   #5
Fridge is mounted on the left side wall. What's more important - front to back leveling or side to side? I really don't want to worry about doing this unless we are camped for more than one night or if we are obviously on a slant (stuff rolling off the table).
Old 06-23-2016, 08:58 AM   #6
grumpy0374's Avatar
As SeaDog stated, practice.
I have two small levels, Camco #25503. Cheap, but good for what I needed.
In my driveway, got my Lexi Level using a regular carpenters level to get right on the money.
Took one Camco level and foung a place on the dash to mount it via double stick tape. This is for side to side.
Found a place on the plastic trim above the drivers door to mount the front to back level.
Now, when I pull into a spot, I can look right at the two levels and see what needs to be done.
I use the "leggo" type blocks which are 1".
After you get used to it, you'll be able to tell almost exactly how many blocks you'll need, and be able to avoid the "pull on, pull off, pull on, pull off" routine.
Grumpy
Steve & Cheryl + Zoey, and Ziggy, our furry kids.
2012 Forrest River Lexington 283ts
Toad, 2013 Subaru XV Crosstrek
grumpy0374 is offline   Reply With Quote
Old 06-23-2016, 09:02 AM   #7
Is this the type of level you are referring to?
https://www.amazon.com/dp/B000EDSSDY
Old 06-23-2016, 09:07 AM   #8
SeaDog's Avatar
Both are important IMO. However it's your rig so you need to do what you feel it best for you and your camping experience.
Retired Navy
Old 06-23-2016, 09:11 AM   #9
Yes...my bad...should have referred to bullseye level instead of bubble level. Mine only has the innermost ring so that is the marker ring to which I was referring.
2016 Microlite 21DS
Blue Ox SwayPro
Old 06-23-2016, 09:22 AM   #10
RedLdr1's Avatar
It is not just the fridge that can be an issue. The "W" has a very large, heavy, slide out. There is a lot of weight extended out quite a distance on that configuration. If you are not close to level you can damage the slide out motors trying to extend or retract the slide.
We had a "W" floor plan MBS. When I leveled our "W" I tried to get the drivers side about one to two degrees higher than the passenger side. Then when the slide was extended that put me very close to level. Check out the Mercedes Benz Sprinter Chassis subforum for more info.
Wayne
2024 Sunseeker 2150SLEF / Ford E-350
RedLdr1 is offline   Reply With Quote
Old 06-23-2016, 09:43 AM   #11
My first RV was a tt in 1974 and I always heard that the level had to be right on for the refrigerator to work properly. I used a round bubble level in the bottom of the refrigerator to check for level. Refrigerator never seemed cold enough. I checked the level with a 2 foot level on the floor and it didn't make any difference. Darn thing would never get real cold. Once we went camping and arrived late and didn't have time to set the camper up we just went on to bed. We were leaning slightly to one side, not enough to mess our minds up but the bubble was out of the center of the round bubble level. Woke up the next morning and the refrigerator/freezer had never been that cold before.
After that we always set the camper slightly off to get the refrigerator to cool like we wanted. We had that camper 12 years and the refrigerator never failed us once. We almost always kept it on gas, but it worked ok on electric also.
Next RV was a motorhome. That refrigerator would keep ice cream frozen in the freezer compartment. We always tried to level it close, but we didn't have leveling jacks only a good stock of wood to put under the wheels.
After going 15 years without an RV we bought a motorhome 5 moths ago but I haven't even turned on the refrigerator. We haven't taken it out camping yet. Maybe next week. I can't believe we are retired and never have as much time as when we worked full time.
Wattsworld is offline   Reply With Quote
Old 06-23-2016, 10:02 AM   #12
DaveSchwartz's Avatar
It is most important to have an absorption fridge leveled side-to-side - in the case of a side-mounted fridge, that is leveling the RV front-to-back.
Referring to this image
the reason is that the working fluid condenses and flows back to the boiler through a zig-zag arrangement of tubing. If the fluid is allowed to pool and slow down at any point before the boiler (i.e. one of the switch-backs becomes level or up-hill) crystals can form that will no longer convert back to liquid or vapor. Then it just snowballs until the tube blocks and the whole plumbing system has to be replaced.
There's more information than you probably ever wanted to know at http://www.rvdoctor.com/2004/02/rv-a...on-basics.html
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
Old 06-23-2016, 10:20 AM   #13
Why did you sell yours?
Old 06-23-2016, 01:04 PM   #14
The fridge will die when the coils get clogged and it's a very expensive fix. Leveling takes no time at all once you get the hang of it
Just the 2 of us is offline   Reply With Quote
Old 06-23-2016, 02:04 PM   #15
CaptnJohn's Avatar
Or call the dealer and have Ground Control 3.0 installed. As an old guy I like pushing the button and be level in 90 seconds or less while it does all the work.
2022 Montana 3855 BR
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
Old 06-23-2016, 02:05 PM   #16
ben31's Avatar
I found Andersen Levelers to be the easiest way to quickly level my trailer. Small, and can take the place of up to 3 leveling blocks.
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2016 Ram 3500 Laramie 4X4 6.7 Cummins Diesel
Never Enough Time Camping!!
ben31 is offline   Reply With Quote
Old 06-23-2016, 02:24 PM   #17
grumpy0374's Avatar
OP has a class c motorhome. Those won't work.
Grumpy
Old 06-23-2016, 02:29 PM   #18
Thanks.
Since I worked 40+ yrs in home construction I have a 4' level by just looking at bubbles I can tell how much I need to level. After some practice it should be easy for you to do this.
Myrle is offline   Reply With Quote
Old 06-23-2016, 02:58 PM   #19
Dahagen
I was told by an RV service man that with the newer (after 2000) refers that if it's just for a few days....as long as you don't roll out of bed you are OK.
dahagen is offline   Reply With Quote
Old 06-23-2016, 03:28 PM   #20
I have nearly 19,000 mi. on my 2014 Solera 24S. I have arrived many times late in the evening at campgrounds or home and have been too tired to level it perfectly. I too frequently just stay for the night and don't want to hassle with blocks and don't bother hooking up my water & sewer line. I just hook up to power. My frig still works fine. I do turn it on a day before a trip to get it cool enough. I did learn my first week of camping why it's good to be level, left to right. I opened an upper cabinet and a pile of dishes slid out and hit me on my head, hard.
( I store the dishes more secure now also.)
mtnlvr is offline   Reply With Quote
fridge
