03-20-2016, 07:05 AM
How to access IRV 33 in a Rockwood mini light 2109s 2016
Hi all, Brand new mini light, all set up in the yard and there appears to be no power to the unit. How can we access the wiring to make sure it is actually plugged in?
03-20-2016, 07:15 AM
Is it plugged in to the house? Does anything work at all?
2019.5 Rockwood 2509S
03-20-2016, 07:20 AM
Yep plugged in, tv works, lights work....everything else works....it does nothing.....
03-20-2016, 07:38 AM
On the front on the left and right sides are covers that come off. The covers run rom the top to the bottom there is a little slot to put a small screwdriver in it pop them off. Under the cover should be 3 screws on each side. Remove those and it will slide out and you should see about 9643 wires back there.
03-20-2016, 07:39 AM
We are going out to look now!!!! Thanks!!!!
03-20-2016, 08:05 AM
Are you sure you did not miss one
Loved your line there, nice to get a laugh first thing in the morning.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
03-20-2016, 08:58 AM
It worked fuse was blown! First repair. DH says screws require a square combo bit or #2 Phillips with square tip. #1 Phillips would just spin. Thank you for help!
03-20-2016, 12:05 PM
Left Coast
Every screw in your rv will be a square headed ....buy a bit or two of different lengths
03-20-2016, 12:07 PM
IRV33 radios are notorious for a couple other problems you might want to check out.
When you turn the radio on, there should only be Zone 1 active. If Zone 3 (outside speakers) is also active and you have to turn it off, they will have to replace your radio.
Another issue well known to them is at Forest River, when being installed, the techs have a habit of plugging the RCA jacks from the TV into the Audio out instead of in. It is what carries audio from the TV down and thru the IRV33.
I had to have three different radios installed in mine before they got a good one.
Always use the square bit on the screws, a phillips will round out the screw and then it will need to be drilled out.
Coming Soon.....To A Campground Near You!
2015 FR Rockwood Ultra Lite 2304 DS
2014 Nissan Titan CC SV
03-20-2016, 12:38 PM
Canadian Member
The square bits are called Robertsons...a Canadian invention!
03-20-2016, 01:20 PM
Square bits
And Canada, they work really well, thanks!
David Cournoyer
2015 F250 SRW 4x4 Crew Cab Platinum
6.7L Powerstroke V-8 Diesel
2013 Rockwood Windjammer 3001w Diamond
03-20-2016, 01:55 PM
IRV33
As stated by others check out all the feature on this unit. Many have issues. I just took my unit in (brand new) because the tech wired it wrong, couldn't get the bluetooth to stream music, and the menu button on the remote was non functional. In short the unit(IRV33) is a piece of !@#$$ but you paid for it so you may as well get a working one.
03-20-2016, 02:02 PM
Georgia Rally Coordinator
Well now we know who to blame for having to buy another tool Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
03-20-2016, 02:19 PM
Yep, EVERY RV owner needs to have Robertson screwdrivers.
They've been standard in RVs for many years.
03-20-2016, 09:57 PM
And don't forget that every time you use that Robertson's' Bit you should pay 25 cents royalty to the Canadian government. Just look up: Canada-Pay the Piper.com"
04-09-2016, 09:43 AM
Ambassador
I had similar issues with my IRV 33. I called the Mfg. They sent me a new one for free. It was fubar.
2016 Ford F250 Crew Cab 6.2 L w/Ride Rite Air Leveling System.
2017 Rockwood Signature Ultra Lite 8335BSS
04-09-2016, 10:04 AM
But we charge you 25cents every one shipped across boarder
Later RJD
Days camped 2019 62
