Old 10-14-2018, 02:17 PM   #1
stormer's Avatar
Question How to get cable in bedroom?
Maybe it's just not possible? I am at a campground that has free cable. If I plug the cable on the "outside" into what appears to be satellite...
Then plug the inside cable in the entertainment center to "satellite" it works and I can find cable channels when scanning...
If I leave it in the bottom coax and do scans I only pick up OTA channels. I've tried swamping the cable on the outside but it doesn't find any channels at all.
Now, that said, in the bedroom, I see this...
I get zero channels either cable or OTA in the top plug. I can "only" get OTA channels in the bottom plug.
This is a 2018 rockwood 2906WS. Is the bedroom just not wired to get cable when you plug it in?
As it stands now with cables in the pics you see above, I get cable in the living room and only OTA channels in the bedroom.
Any ideas? Am I goofing it?
Thanks!!
James
James & Aimee
2018 Rockwood 2906WS
2012 Ram 2500HD 6.7L Cummins
Equal-i-zer 4 Point Hitch
stormer is offline   Reply With Quote
Old 10-14-2018, 02:37 PM   #2
bikendan's Avatar
Did you turn off the antenna booster button?
Old 10-14-2018, 02:38 PM   #3
bubbles's Avatar
Connect the park cable to the cable port (left one). Move the front TV connection to the TV port. Leave the bedroom as is. Turn off the OT antenna booster and set the TV"s to cable and run a scan. See if that does it.
Old 10-14-2018, 03:36 PM   #4
stormer's Avatar
OK! Well, that did the trick. Moved it to outside cable, moved inside cable to TV and left bedroom alone. Turning off the OTA power did the trick! Well, sheesh, I would never have figured that out. LOL! Thanks a lot!!
James
James & Aimee
Old 10-14-2018, 03:54 PM   #5
Turning off the antenna power switch not only keeps power from going to the antenna, it also switches the input (behind the wall plate) to the coax connected to the outside cable port.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
bed, cable, roo
