Old 08-12-2017, 09:51 AM   #1
How to remove microwave
We have a 2017 FR3 that got an electrical backfeed from a bad electrical connection. The microwave had a pop sound, the microwave panel does not work but the interior light does. We want to remove the microwave to check the fuse but can't figure out how to remove the microwave to get to it. Can't find any screws in the upper cabinet. There is a metal bracket for the hood below.
RVer1976 is offline   Reply With Quote
Old 08-12-2017, 10:07 AM   #2
crunchman12001's Avatar
Can you provide a picture of the Microwave, bracket and cabinet surround?
Hindsight is 20/20... You need to install a Progressive Industries EMS, this would have prevented this from happening.
2015 F-250 FX4
Old 08-12-2017, 12:07 PM   #3
I am new to this forum andwill post a picture once I figure out how.
Old 08-12-2017, 12:36 PM   #4
Briorick's Avatar
Here is 1 of a few RV Microwave removal / install videos on youtube. May not be the same as your microwave, but installs are pretty much done in the same fashion. Check out the others if this one does not help. Just type in RV microwave install, or removal.
Rick & Brian
1 Happy Camper Pup ( Mya )
2017 Salem Cruise Lite 232RBXL
2004 GMC Sierra 2500HD LT 4x4 6.0 / 4:10
The best plans can be of those that happen in the spur of the moment!
Briorick is offline   Reply With Quote
Old 08-12-2017, 02:58 PM   #5
I just replaced a Furrion (sp?) over the stove convection microwave that was installed like one in a S&B. I would be happy to explain how if that's what you have.
Robert Shorter
2015 Dodge 3500 DWD
Blue Ridge 3500RS
rmshorter is offline   Reply With Quote
Old 08-12-2017, 05:30 PM   #6
Thank you. Our challenge is that videos indicate the need to remove screws in the upper cabinet. None are visible. There is a grill on the upper part of the microwave and we're looking for a way to remove that with no luck.
Old 08-12-2017, 06:35 PM   #7
I needed to gently remove the upper trim, so I can reinstall. Gently remove the board above the microwave, so I can reuse it. That exposed the screws to the top of the microwave. Although I had to remove the screws to either side of the board that held the microwave up to remove the screws to the microwave
Robert Shorter
2015 Dodge 3500 DWD
Blue Ridge 3500RS
Old 08-12-2017, 08:01 PM   #8
Thanks. We'll try that.
Old 08-12-2017, 08:41 PM   #9
Iggy's Avatar
Yes. Like rmshorter said.
2012 Georgetown XL - 378TS 55,000 miles & counting
Iggy is online now   Reply With Quote
Old 08-13-2017, 12:41 PM   #10
Senior Member - Retired
I posted some pictures in the thread below detailing how to remove the Magic Chef microwave in our motorhome.
It may be applicable to your situation. Good luck!
Forest River Forums > Motorhomes > General Motorhome Discussion > Georgetown > Magic Chef Microwave Starts On Its Own
John & Gloria Hunsaker FROG Member CA-0030-988
2014 Georgetown XL 334QS (class A with 4 slides)
2013 Smart Car TOAD
Blue Ox Aventa LX tow bar, base plates, diode kit
SMI Stay-IN-Play Duo auxiliary braking system
25' Off shore blue water fishing boat
CA Fisherman is offline   Reply With Quote
