Old 07-24-2015, 08:47 PM   #11
Originally Posted by bob caldwell View Post
Some have a small cable attached to retain tv so it won't 'jump' out of bracket while traveling.
Yep, looks like there is a cable in the back holding it down. Anyone have an idea where the other end could be attached or is this something you just have to cut?
vaiopeanut is offline   Reply With Quote
Old 07-25-2015, 07:46 AM   #12
ov845's Avatar
Don't cut! It looks like a video cable. Some mounts have a "snap in" bracket. Firmly grabbing the TV from left & right sides, pull towards you. If you feel one side give more than the other side, pull a little harder on the opposite side. Hope this helps.
Happy Camping!
2012 Ram 1500 5.7L 3.92
2015 2809W WindJammer
Husky Centerline WDH
ov845 is offline   Reply With Quote
Old 07-25-2015, 09:22 AM   #13
Happy Camping!
Just tried it. It won't move.
The cable is certainly a metal wire. There are other cables attached in the back and they are video cables. So unless I am missing something that's got to be the reason.
It's a very thin metal cable (half the gauge of the other video cables in the back) that is very tight. If I poke it with something, it shakes the TV a little.
Old 07-25-2015, 09:34 AM   #14
dcheatwood's Avatar
2 thoughts.... Put your camera under and beside the TV to see if you can get clear pictures of the mount.
Also, there may be a tv mount owners manual in pack of RV paperwork. Maybe it'll show some pointers. Good luck.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 07-25-2015, 10:44 AM   #15
That was a good idea!!
It confirms there is indeed a cable holding down the TV. Now I just got to figure how to get to the other end of the cable to disconnect it. It goes into the same hole as the video cables come from. I am thinking about taking off the radio to see if it shows were it goes.
Edit: I looked through the Docs and no information on the TV mount..Just the TV itself
Old 07-25-2015, 03:31 PM   #16
Solved!
The other end of the cable was behind the radio. Once I removed the screw it was ancored to, I was able to easily lift the TV off the mount and put my HDMI cable behind it.
Thanks for the all the help everyone!
Old 07-25-2015, 03:57 PM   #17
Georgia Frog Rally 2018
aceinspp's Avatar
Thanks for the end result. Guess I can do mine next as my set up is just like yours only in a V-Lite. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
Old 07-25-2015, 07:47 PM   #18
dcheatwood's Avatar
Great. Don't you just love this place?!
windjammer, 210
