Old 07-21-2015, 07:21 PM   #1
How to Remove the TV in Windjammer 2102W
HI Everyone,
I searched through the forums but couldn't find information on how to remove the TV for my camper. It's a 2009 Windjammer 2102W.
I want to remove it so I can get to the ports on the back of it to plugin components. For example a Xbox for the Kids. There are Component ports on a white panel below the TV. It's labeled "Game" and Cable/Satellite". I assume that's where you are suppose to plug in components. But I plugged in a working Xbox and went through all the "inputs" on the TV and nothing showed up. So I was thinking about going directly to the back of the TV and plug it in.
Problem is I don't see a way to get back there. The TV doesn't move. There is only about a inch of space between the TV cutout and the TV on all sides. I don't see any door or panel on the sides. I will try an attach a photo
vaiopeanut is offline   Reply With Quote
Old 07-21-2015, 07:35 PM   #2
Georgia Frog Rally 2018
aceinspp's Avatar
I think you need to go through the radio settings to get it to work. Same as getting the TV to go through the speaker system. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
aceinspp is online now   Reply With Quote
Old 07-21-2015, 09:29 PM   #3
D_B Travelers's Avatar
TV removal
I have a 3001w and the TV is on a mounting bracket that lets you lift it off. Perhaps that will work for yours also. I have a bit more space around mine, but I just lift up on the TV and then you will feel it disengage from the bracket. Hope that helps.
D_B Travelers - 8 nights in 2018, 58 nights in 2017. [U]1st love: 2014 TT WJ3001w, now 2016 40' FW SOB, 2015 GMC 3500HD CC DRW Duramax, TST 507rv TPMS.
"Happiness? A good meal, a good cigar and a good woman - or a bad woman; it depends on how much happiness you can handle."
George Burns (1896 1996)
D_B Travelers is offline   Reply With Quote
Old 07-22-2015, 10:56 AM   #4
That did it, thanks!!! It's not very intuitive but it's working. Thanks again!
Old 07-22-2015, 10:58 AM   #5
Mine must be a little different. Can't lift it at all...Very odd. I'm obviously missing something. Would love to be able to use one of the HDMI ports on the back of it as the panel on the front doesn't have a HDMI port but the TV clearly has one.
Old 07-22-2015, 11:11 AM   #6
Left Coast
Some have a small cable attached to retain tv so it won't 'jump' out of bracket while traveling.
Old 07-22-2015, 11:31 AM   #7
Dazed & Confused
M&K Hoffman's Avatar
I have a 3008W and one must grab both sides of the TV and pull straight forward. The TV moves out some and allows it to be rotated left and right. It also give one enough room to access the jacks on the back.
~Mike & Kim~
2014 Rockwood Windjammer 3008W Diamond Package
2012 Toyota Tundra Doublecab 5.7 4WD
M&K Hoffman is offline   Reply With Quote
Old 07-22-2015, 11:35 AM   #8
ov845's Avatar
X2
Happy Camping!
2012 Ram 1500 5.7L 3.92
2015 2809W WindJammer
Husky Centerline WDH
ov845 is offline   Reply With Quote
Old 07-22-2015, 11:39 AM   #9
fonzie's Avatar
Could there be an access panel through the bottom of TV cabinet just above Concertone that you can remove and then access back of support for TV??
Fonzie
Old 07-22-2015, 01:53 PM   #10
Lloydg's Avatar
Send a message via AIM to Lloydg Send a message via MSN to Lloydg Send a message via Yahoo to Lloydg
I've never removed mine, but have been told that I'm to grab a strap that hangs down from the back and to pull on it. That's suppose to release a catch and it's suppose to come off. I haven't tried it just to try it because I'm afraid it's will be a real pain to get back on. I may have to try it , however, because I'd like to attach a HDMI cable very soon.
Heartland Big Country 3150RL
2013 Ford SD F250 4x4 SC; 6.2
Reese 18K Elite w/slider - Ada, Michigan
Lloydg is offline   Reply With Quote
windjammer, 210
