Old 07-04-2016, 05:24 PM   #11
JEEP's Avatar
I have the same unit (2010) and added an additional camera alongside the original one. One keeps an eye on the toad and the other the entire rear scope so I can see upcoming traffic and passing trucks etc. I bought the unit as 'used' with only 7500 miles and believe I did receive all relative manuals including the rear view mirror monitor. I was told Forest River purchased a large quantity of these monitors, however they are no longer available for parts. Good luck on your quest for a solution to your issue.
JEEP is offline   Reply With Quote
Old 07-05-2016, 12:26 AM   #12
2007 WildCat 32QBBS
05CrewDually's Avatar
Some cameras have a small wire near the main plugs. If you cut the single small gauge wire (usually red or blue wire) it will flip, or mirror, the image.
I'd remove the camera and inspect the wires. Post a picture of the harness if you can.
Here's a picture as an example. The camera may be different than yours.
Just fully read original post. This info may not pertain to you. Disregard.
05CrewDually is offline   Reply With Quote
Old 07-05-2016, 06:55 AM   #13
Wolverine 1945's Avatar
I am guessing ours is the Magnadyne ???
I have never seen either in the menu or the booklet anything about changing image ?
Wolverine 1945 is offline   Reply With Quote
back up camera
