Old 07-03-2016, 02:43 PM   #1
how to reverse image from Back up camera
How do you reverse the image in the back up camera? This is in a 2010 Sunseeker 3100, and the image is displayed in a rear view mirror replacement monitor. The only name I can find is TFT LCD on the remote. I have gone thru the menu and there is no option to change the orientation. For this camera there is no control box under the steering column. Unfortunately if there was an owners manual that came with the Motorhome it is no longer with the other manuals. I recall having to do something with the remote to get the image to reverse when we purchased it new, but do not remember what it was. The dealer service department did not recall either. I have searched the forum and everything I have found does not address this model of camera for this issue.
Jody Cook
Georgetown TX
JCook1 is offline   Reply With Quote
Old 07-04-2016, 05:08 AM   #2
Head Rambler
Hopefully someone with your model will come along and have the answer you need.
What is the brand of the backup system?
Gotta go campin!
Old 07-04-2016, 05:15 AM   #3
Sky&Scuba
kendive's Avatar
What's the model of the LCD Screen?
I have one of these when I setup my wireless camera on my camper and it allows you to flip the image in any direction.
https://www.amazon.com/Sunvalleytek-...dp/B004Y3FE6O/
If anything you could buy a new monitor such as this that allows you to flip the image.
2015 F150 3.5 EcoBoost Lariat FX4 502A 3.55 Gears Max Tow KO2 Tires
2017 Grand Design Imagine 2150 RB / Traded in Catalina 253RKS
kendive is offline   Reply With Quote
Old 07-04-2016, 08:56 AM   #4
There is no name on the monitor. It is one that looks like a rear view mirror, but is only a monitor (no mirror function).
Old 07-04-2016, 12:23 PM   #5
Lewis96's Avatar
Cool
I have a 2010 FR Lexington with a MobileVision Color Rearview Camera Model C125. The Rearview mirror is a Magnadyne Mirror/Monitor.
I do not know if this helps but in the camera instructions under Troubleshooting " Upside Down Image" / Solution is "Check Camera Mounting"
Good Luck!
Lewis96 is offline   Reply With Quote
Old 07-04-2016, 12:25 PM   #6
Mine has a Magnadyne M4 here is a link to the manual.
M4-LCD Magnadyne Touch Screen GPS Navigation Car Stereo
If you want to display the view on the dash screen that is done on the dash unit not the "mirror" monitor.
edcronin01 is offline   Reply With Quote
Old 07-04-2016, 12:32 PM   #7
jaibyrd's Avatar
I believe you just need to push the right or left arrow or the mode select button to scroll through the different images on each camera. should be normal, reverse, and the upside down normal and reverse. I can double check that later if it doesnt work for you but its for sure one of the buttons, you don't need to go to the menu.
Snyder Family - Pelham, NH
2015 Sunseeker 3170DS
jaibyrd is offline   Reply With Quote
Old 07-04-2016, 12:51 PM   #8
I have a 2016 Sunseeker 2700 DSF with the same camera system. Manufacturer is RVS Systems. Use the internet to download their manual. Page 14 states to rotate image, press Menu (M) 7 times then use UP & Down Arrow keys to orient the image. Hope that helps. Also the multiplexer itself has a "Mirror/Normal Switch", but I don't know where the multiplexer is mounted. Try above first.
pkeene is offline   Reply With Quote
Old 07-04-2016, 03:01 PM   #9
Thank you for all the replies. Pressing the Menu button scrolls thru video settings, (contrast, color, etc.) From an old post here I think it is possibly a Chinese made system. It has a round, white camera and the monitor is a rear view mirror replacement. It has no monitor in the dash/radio.
Old 07-04-2016, 03:45 PM   #10
Like pkeene, I have a 2016 Sunseeker. Here is a link to the rear monitor system we have:
RVS-770619N | Backup Camera System with 7" Replacement Mirror Monitor | Rear View Safety
Compare the unit in the link to yours. If this is the same as yours, his instructions are good to follow.
Wayne Lee
Out West Somewhere
2016 Sunseeker 3050DS towing 2006 Hummer H3
WayneLee is offline   Reply With Quote
back up camera
