Old 05-23-2014, 06:47 PM   #1
How to swing out TV?
I had ky new camper out once and didn't spend a lot of time trying to figure it out, but how do you swing the TV bracket out. Mine is locked in position and I can't see how to unlock it.
Thanks.
2014 Sunseeker 2860DS
gmacklem is offline   Reply With Quote
Old 05-23-2014, 11:12 PM   #2
Oklahoma Proud
MillerTime's Avatar
Does it swing out? My last trailer had, slide-up to remove brackets that the tv hung on. One plate on wall and one on tv.
If it is a swing out than there should be a pin or release button somewhere.
Sorry if this doesn't help much.
MillerTime- Future Sabre Handler!!
Old 05-24-2014, 07:30 AM   #3
Jimandchris's Avatar
On our Roo the mount has a u shaped plastic lock. You grab the top and bottom of the tv and pull straight out to unlock it. Then it will swing to where ever you move it.
2014 Roo 23ss, 2013 GMC Sierra 1500 Crew
2019 Coachmen Freedom Express 281RLDSLE
2018 2500 HD Silverado
Equal-i-zer Hitch E4
Jimandchris is offline   Reply With Quote
Old 05-27-2014, 06:54 AM   #4
Thanks, that is what I ended up doing and it worked. I had to pull a little harder than I wanted to and was afraid I would break the TV, but it finally came forward and let me swing it sideways.
Old 05-27-2014, 07:16 AM   #5
You're welcome, during our PDI the tech showed us to pull using top and bottom of the tv instead of the ends, bit more sturdy that way. Got the impression someone may have broken a tv off at the mount previously.
Sent from my SAMSUNG-SM-T217A using Forest River Forums mobile app
