Old 11-29-2014, 02:22 PM   #1
Exclamation How to turn up temp on water heater in Palomino Solaire 297Rlds
Good afternoon all,
I'm having issues figuring out how to turn up the temperature on our water heater in our travel trailer. I've tried calling the service department and they are closed on weekends. I've also looked through the paperwork they gave us at the time of purchase but there is nothing in it about the water heater specifically, other than it mentions we have one. The switch for the water heater is on but at best it gets lukewarm, at worst it's cold. The flame under the heater was going but at this exact moment it's not. But even when it is the water temperature does not get much hotter. Hoping someone on here has a quick answer for me. Thank you all in advance.
rmrichardson is offline   Reply With Quote
Old 11-29-2014, 03:04 PM   #2
how do you have the water heater bypass valve positioned ?
sparkync1 is offline   Reply With Quote
Old 11-29-2014, 03:26 PM   #3
fonzie's Avatar
Your by-pass valve on your water heater is most likely open. Top picture show normal operation, bottom picture show by-pass winterized mode.
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 11-29-2014, 03:29 PM   #4
TURBS's Avatar
X2 check your wh bypass valves.
Also if you recently used the outside shower did you leave the handles on and just shut water off with shower head?
No way to turn up HW heater temp via a temp setting switch.
TURBS.
Old 11-29-2014, 03:41 PM   #5
I'm not sure. What does that look like? I'm new to owning a travel trailer so I'm still a little lost
Old 11-29-2014, 03:42 PM   #6
Oh goodness thank y'all. I will go check that now. See if I can figure it out.
Old 11-29-2014, 04:37 PM   #7
TURBS's Avatar
Btw do you have a gas and electric wh?
TURBS.
Old 11-30-2014, 08:37 AM   #8
davel1971's Avatar
I've never had one that is adjustable. Anyone know if any are or if you can get an adjustable thermostat?
David & Lynn
Old 12-08-2014, 07:30 PM   #9
bikendan's Avatar
most rv WH's don't have adjustable thermostats. i think you can buy one and swap it out.
Equalizer WDH
Old 12-08-2014, 08:45 PM   #10
Fulltime family RVer
As Dan said, few are and none would cause this coldness of water. That is almost definitely a sign of cold water mixing with the hot IF the water in the water heater is hot. Have you tried letting water come out of the relief valve to see if it is cold or hot? If it is hot, your water heater is fine. If it is cold, then you're looking at a thermostat, heating element, or other problem.
heater, palomino, water, water heater
