Old 10-13-2015, 11:32 AM   #11
Tom48's Avatar
Originally Posted by Thurman View Post
I actually don't know what brand this new antenna is. I do know that the old one looks like the picture in post #2. This new one appears to have the "wings" as the old one but is a fixed position as far as height and direction. There are NO controls for the antenna on the inside of the TT.The new one is aligned with the length of the TT. I just went out to finish cleaning the TT, turned on the TV and did a channel search with the little red light on. Four channels with two TV stations within five miles of my house. Four channels that did not come in clear enough to watch. I am going to look into the "Jack" antenna.
Please, send us a picture. Also a picture of any inside control panel.
Tom48 is offline   Reply With Quote
Old 10-13-2015, 11:39 AM   #12
Stormrider151's Avatar
I had the same anntena you have on my Salem. It work ok as long as you were within 40 miles of a metro area. Outside of that, nothing. Your best bet is to replace it with a sensar or a jack. I went the direct tv route. Expensive up front but has paid for itself over the years.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 10-13-2015, 11:46 AM   #13
Lloydg's Avatar
Send a message via AIM to Lloydg Send a message via MSN to Lloydg Send a message via Yahoo to Lloydg
What I'm sure you have for an antenna is what is called an Omni directional antenna and is "supposed" to pick up stations from all directions without the need to rotate. Well guess what? They don't work very well. As others have said, they replaced the Omni directional with the Jack and I have as well. Suggest you check out the reviews on-line and I think you might too.
Heartland Big Country 3150RL
2013 Ford SD F250 4x4 SC; 6.2
Reese 18K Elite w/slider - Ada, Michigan
Lloydg is offline   Reply With Quote
Old 10-13-2015, 11:53 AM   #14
It is probably an Antenna Tek antenna....which works the same way the sensor does....Why can't you turn the antenna to face the station? Just grab the outside ring, pull it away from the ceiling about a 1/2" then turn it till you get a good picture...
Bob Vaughn is offline   Reply With Quote
Old 10-13-2015, 11:54 AM   #15
ARLO
We have the King "Jack" antenna and it works as good as our old Sensar antenna if not a little better.
rlocicero is offline   Reply With Quote
Old 10-13-2015, 11:54 AM   #16
Boss Ox & Drovergirl
oxcamper's Avatar
We have the same as Thurman. Cut post off the one picured and mount it about 4 inches above the roof and that's what it looks like. Doesn't rotate, doesn't raise, it can not be adjusted. there is a booster switch on the panel inside where the TV plugs into but that doesn't help much. Yes there are cable jacks for outside connections but we're not in a park that has cable.
Overall TV isn't a big part of our lives so there's little loss for us.
Mark, Vicki, & Scout THE dog
2015 Hemisphere 282RK
2010 F250 Super Duty
1992 Goldwing Aspencade
oxcamper is offline   Reply With Quote
Old 10-13-2015, 11:55 AM   #17
Left Coast
Stationary ant...does not rotate
Old 10-13-2015, 12:00 PM   #18
oxcamper's Avatar
There is nothing inside where the antenna mounts, the outside is screwed onto the roof and sealed.
Old 10-13-2015, 12:04 PM   #19
I am not surprised ......we looked at a 34' travel trailer that had no closets, not even a shirt closet....them mfg. rep stated it was a weekend camper and you brought suitcases....duh if I was going to camp out of a suitcase I would go to a motel....
Old 10-13-2015, 12:10 PM   #20
drojr
If you have a smart phone get an app to show you the direction the signal is coming from. Such as "DTV Antennas" shows the direction and distance to the source of the signal.
droilerjr is offline   Reply With Quote
antenna, antennae
