Old 10-15-2015, 06:03 PM   #41
Dodge Guy's Avatar
I had the old style crank up antenna. It never really worked good. It pulled in the local Chicago stations OK until the switch to Digital. Then it stopped getting any stations! I switched to a Jack and I can now get 70 stations in my Chicago suburb driveway. Even at a couple local campgrounds wherei could never get any signal I can now pull in at least 10 stations from either Rockford or the Quad Cities. It's a great antenna!
02 Ford Excursion V-10 4.30 gears 5 Star Tuner Y-pipe mod Hellwig sway bar Rear Airbags
Prodigy and Dual Cam
07 Cherokee 32B
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
Old 10-15-2015, 06:24 PM   #42
Flybob's Avatar
Originally Posted by Bob Vaughn View Post
Are there any instructions with it that tells what brand it is??
Here is the info on the antenna, It is junk in my opinion. If you want to use the TV get a Jack. The design says directional, the manual says omni directional. Can't be both.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 10-15-2015, 09:02 PM   #43
Timex's Avatar
Originally Posted by pdqparalegal1 View Post
We purchased the "King" replacement for the Wineguard antenna. Mounts on the same mast. Works great. Just aim close and get many chanels.
I did the same thing but the results are the same as I had before. If the wind was blowing hard, I would lower the batwing. Not as worried about the Jack. If the wind were to blow it off, it might do me a favor. Digital signals are good and clear when they are good and clear. When they are not, you say dirty words. There is not much on TV worth watching anyway.
2012 Flagstaff V Lite 30 WRLTS
2005 Dodge Ram 2500 5.7 Mag Hemi 3.72 Rearaxle
Nights camped 2015 = 23
Nights camped 2016 = 25
Nights camped 2017 = 13
Nights camped 2018 = 3
Timex is offline   Reply With Quote
antenna, antennae
