Old 09-22-2013, 09:13 PM   #11
jimh's Avatar
mine would drift so i replaced it with a hunter from walmart. cost was ~$25. i've read that u can replace it with any that has battery backup.
i'll see if i can find the wiring diagram for it. i can remember that Rh and Rc are connected to common. there is a 7.5v line that isn't used.
we were on the road half the summer and had no problems with the replacement.
the other thing is that the hi and low fan both connect to the fan terminal. u loose the ability to switch from high to low fan...it stays on hi. i didn't use the low speed anyway. u can solve that with an external switch.
try this:http://www.flickr.com/photos/rests/s...7618469312797/
jimh is offline   Reply With Quote
Old 09-22-2013, 10:54 PM   #12
BillyBass's Avatar
Originally Posted by Bucket-hat Otis View Post
Sorry about the IMG size Ford Idaho, what's wrong with it?
BillyBass, I think the breaker is doing it's job. Isn't there supposed to be a minimum amount of time, say 5 minutes, before the air conditioner kicks back on?
I just thought about what I went thru with no power to my outlets and I found a loose wire.
2012 21' FR Micro Lite FBRS
2005 GMC Sierra 1500
2012 24 nites 2016 16 nites
2013 25 nites 2017 19 nites
2014 14 nites
2015 16 nites
BillyBass is offline   Reply With Quote
Old 10-06-2013, 08:59 AM   #13
I installed the new thermostat with no problems and it works like a champ! I went with the programmable Honeywell instead of the Hunter because that's all my local Walmart had in stock. I also spent the extra money on the programmable Honeywell because I'm bad about leaving for work and forgetting to turn the thermostat up. My trailer stays nice and comfortable all the time now. I want to give a big thanks to everyone here. The information contained in these forums is worth it's weight in gold. THANK YOU SO VERY MUCH!
Bucket-hat Otis is offline   Reply With Quote
thermostat
