04-07-2016, 01:00 PM
#241
Western PA Happy Campers
Just called Todd Eash and he is sending a new unit today! Thanks to all who ferreted out the contact info to solve these radio problems. X2 on the optical cable.
2016 Flagstaff 27RLWS Emerald Ed.
2014 Chevy Silverado LT w/ 5.3
Reese 12,000lb hitch w/ Dual Cam Sway Control
04-09-2016, 09:38 AM
#242
Ambassador
Got mine replaced because of this issue. New one works much better.
2016 Ford F250 Crew Cab 6.2 L w/Ride Rite Air Leveling System.
2017 Rockwood Signature Ultra Lite 8335BSS
04-11-2016, 07:19 AM
#243
Got it replaced!
Thanx to this forum, we tried out our iRV66 in our new Rockwood as we are preping it for our 1st trip only to discover that it had all the issues everyone else had. I called Todd Eash & received a replacement in less than a week. We installed it yesterday....very easily, I must add and it is awesome! We are happy campers! The only thing I couldn't figure out was how to play the movies on a flash drive. I plugged in the flash & then nothing happened. I also put one of those movies on a disc in the correct FAT32 format & also nothing. Does anyone have any tips? I'm not a techy so I hope it's an easy solution.......of course the easiest is to take the few dvds I have or hit Redbox.
04-11-2016, 07:24 AM
#244
Did you select he correct source?
Bruce
04-11-2016, 07:36 AM
#245
Probably not.....hubby was rushing me and was afraid I would screw everything up. I'll be able to fool around with it when we go camping in 2 weeks. I'll take the flash drive with me.....just have to figure out to to set it all up to work correctly.
04-12-2016, 06:31 PM
#246
I've never tried playing movies via USB on the iRV, because I know it won't support the format of a lot of my movies. I know from reading that it's very picky about both the format of the USB storage, and the format of the movie file itself (codecs etc).
I'll be taking a USB harddrive with us on our next big trip, and using the Playstation (which we just use to watch blurays) to play the movies in the main living area, and the samsung bedroom TV for if we want to watch any in the bedroom.
2015 Rockwood Signature UltraLite 8281WS
2016 Ford F-250 Lariat CrewCab, 4x4, 6.2L V8
04-14-2016, 12:08 PM
#247
New iRV 66 showed up yesterday and got it installed. New unit works great! Thanks to Todd at Patrick Industries.
04-16-2016, 08:06 AM
#248
I'd be interested to hear if the visual display on the front of the unit works normally for you. The display on ours jumps around regardless of whether there's any sound, and certainly doesn't work as a normal equalizer display. It's mildly irritating
04-16-2016, 08:52 AM
#249
I talked to Nelson at Patrick Ind (tech guy) and he told me I needed to add component video cables to be able to view video from my iPod and I assume the USB port. When I followed the manual I would only get the sound from the iPod video and TV screen stayed blank. So I'm gong to add the cables and see what happens.
My equalizer also jumps around even with the volume down low, but it doesn't bother me
Retired Navy
2016 Flagstaff 26 FKWS
04-26-2016, 09:42 AM
#250
I just contacted Todd and he is sending an IRV 34 to replace my bad unit. Awesome CS
2017 Columbus 385FL
2017 GMC 3500 HD Dually
04-26-2016, 11:20 AM
#251
Make sure you read the included addendum for the iRV 34. I thought mine was bad because all zones worked except zone 3, which just played static. I was packaging it up to send it back and found the piece of paper that explained that Zone 3 can play a separate source and was actually tuned to FM, hence the static.
2016 Roo 21SS
2005 Ford Excursion-Sherman
Mods so far:
PI hardwired EMC, Wire Shelving in wardrobe
Plexiglass screen door protector, Blue LED Wine nook
stairs, and counting...
04-30-2016, 08:24 AM
#252
Is there a way to switch speaker 3 from the radio to CD? and I wish there was a way to adjust the volume on the outside speakers.
04-30-2016, 08:52 AM
#253
Do you have the iRV33 or 34? See my post above yours about the iRV34.
2016 Roo 21SS
Mods so far:
04-30-2016, 09:13 AM
#254
It's an iRV 34. I just wasn't sure if that meant that it has to stay on FM or not. We had such a good system in our last mini lite that we were disappointed that this didn't work the same. (just don't remember what that system was!)
04-30-2016, 12:41 PM
#255
You can change the source and the volume for zone 3. I'm not home so I don't have the instructions on how to do it. I'll check when I get home.
2016 Roo 21SS
Mods so far:
05-08-2016, 04:29 PM
#256
Sorry I am a year late, but never saw your reply to my post.
Do I understand correctly that to replace my now-fully dead ZX600 and install the iRV66 I need an adapter between that unit's wiring and the existing wiring? Or all of the wiring needs to be replaced?
Thanks.
Originally Posted by Bob Fields
Hello Texas Coyote!
To answer your questions:
1. The units on sale are fully tested and will not have the problems documented here thanks to the good work by the radio manufacturer in resolving.
2. The wiring is not compatible as the ZX600 was the last unit built with that wiring configuration. The follow on ZX690/700 & GT3.0 were changed and t he iRV is a plug and play replacement for those with your wiring harness adapter.
3. The iRV66 has multiple HDMI outputs and is compatible with today's TV's. Don't forget when your ZX600 was built we did not even have some the available audio/video formats that are commonplace today.
Please let me know if you have additional questions and feel free to contact me directly!
05-19-2016, 09:39 AM
#257
In regards to Todd Eash at Patrick Industries, for replacement IRV-66.
This guy is AMAZING. Thank you so much for referring me to him. A few quick questions and my replacement is getting ready to ship!
Thank YOU guys, for having this forum so that newer RV'ers like myself don't pull ALL of our hair out when we have issues!
Kathy
05-22-2016, 01:02 PM
#258
I wrote to Forest River and they sent me these instructions (which weren't included in the booklet with the iRV34 that we got.) I finally got a chance to test it today.
With radio on in normal mode you can turn any zone on/off with a quick push of any zone (! 2 or 3)
To change source for zone 3:
Push and hold zone 3 button until the display reads Z3 followed by the current source that zone is playing, such as Radio/DVD/BT. Then push the mode button to change the source that is on zone 3. Now the volume knob is controlling on the source of zone 3 playback.
To control the volume on zone 1 and 2: Press and hold zone 1 for two seconds and now the volume knob is controlling zone 1 and 2 and all other operations are back to normal.
Hope this is helpful to someone else.
05-22-2016, 03:23 PM
#259
I RV radio
IRV technologies- DVD sound cuts in and out when movie is playing. Is there a fix? I have reset all the system settings. The trailer is brand new.
07-02-2016, 05:41 AM
#260
Thank you NC Robi
We have a 2017 Mini Lite (2109S) with the IRV 34 and in the PDI, they sort of skipped over the IRV and handed us the booklet which doesn't talk at all about Zone 3.
We got home and I turned it on and Zone 3 just blasted away! I shut it down and put it on my list to look at but frankly was a bit concerned about turning it back on as the volume was so loud! I just printed off the instructions you posted and will try it this morning, once everyone is awake!
Campah
2017 Rockwood 2109s Mini Lite
