Old 07-06-2016, 01:22 PM   #261
IRV 33
We bought a 2016 2703WS Rockwood. It has an IRV 33 We watched 1 blue ray movie. Off and on the movie pauses for one to two seconds. We tried to watch another movie & now all we get is reading disc and disc read error? It's brand new !!! Reg DVD movies will play. Blue ray movies will not. Has anyone else encountered this problem? Is there a software fix for it? Thanks !
Camp123 is offline   Reply With Quote
Old 07-06-2016, 04:08 PM   #262
SeaDog's Avatar
The IRV is not a blue ray player check your manual
Retired Navy
2016 Flagstaff 26 FKWS
Old 08-15-2016, 10:49 PM   #263
iRV34 Issue with Zone 3 (Outside) Speaker Volume
I just purchased my 2017 Roo 19 and had the same problem. Chuck from Forest River sent me a quick reference (attached file) and now i am able to control my Zones 1 and 2, and also Zone 3 (outside).
SGM-79S is offline   Reply With Quote
Old 08-15-2016, 10:52 PM   #264
iRV34 Video Format
Does anyone know what the video format the iRV-34 uses when you plug an USB thumb drive to watch a movie? I tried using .mp4 but that does not work.
Old 10-25-2016, 08:48 PM   #265
IRV66
My TT is a 2014 Rockwood 2604WS with the IRV66...otherwise known as the worlds worst stereo. I'm not interested in having a dealer provide a lousy fix for this piece of crap stereo. I checked Mr. Google and found a guy on You Tube that put in a Pioneer car DVD receiver stereo system in his TT. His is am/fm, cd/DVD, BT compatible, provides more power while drawing less juice etc.
This is the route I'm going to take. I spoke with a local car stereo shop and they said that the RV stereos draw a lot of power and he suspected this might be the cause for the stereo cutting out and low points in the audio? At any rate this is the route I'm headed for.
Is there anyone out there that has done this? If so I'd like to talk.
Thx
Dave
Ddfee is offline   Reply With Quote
Old 10-25-2016, 09:16 PM   #266
bikendan's Avatar
You must not have owned a Concertone RV stereo, generally agreed on all RV forums as the world's worst.
Old 11-04-2016, 11:02 PM   #267
We have same issue in our 2017 2703WS emerald edition RV and has not worked since we got it. Also learned that our TV amplifier would not stay on. Going in for warranty work this month. Also video freezes and flashes in and out but sound will keep going.
Rockwood2017 is offline   Reply With Quote
Old 12-19-2016, 09:38 PM   #268
?.....I checked Mr. Google and found a guy on You Tube that put in a Pioneer car DVD receiver stereo system in his TT. His is am/fm, cd/DVD, BT compatible, provides more power while drawing less juice etc.
I am very interested in this, too.
Anyone else here installed this?
TexasCoyote is offline   Reply With Quote
Old 09-30-2017, 09:12 AM   #269
Ambassador
Ken K.'s Avatar
We had ours replaced under warranty with similar issues.
2016 Ford F250 Crew Cab 6.2 L w/Ride Rite Air Leveling System.
2017 Rockwood Signature Ultra Lite 8335BSS
Ken K. is offline   Reply With Quote
Old 04-19-2023, 03:53 PM   #270
irv-66
I used a video converter with the settings resolution 640x352 frame rate 23.976 and bit rate around 800.
The codec needs to be divx and file extension .avi
Works good.
tretrunk is offline   Reply With Quote
Old 04-19-2023, 04:00 PM   #271
We just use a BT speaker and stream music from one our mobile devices. The radio is not a good quality radio.
I wished I’d gone camping sooner in life.
Traveling Circus is offline   Reply With Quote
Old 04-19-2023, 09:01 PM   #272
BriaBeck's Avatar
Thx
Dave
I did this... didn't use a "Pioneer", but I did use a "Dual" branded unit. Also replaced the garbage OEM speakers with more quality speakers. Made a HUGE difference!!
It's really not hard to do at all. Biggest advice I can give is "Don't be intimidated by all of the wires." It really isn't that complicated. I'll try to help as much as I can!
ID:	286146   Click image for larger version
ID:	286147   Click image for larger version
ID:	286148   Click image for larger version
ID:	286149   Click image for larger version
Brian & Becky
2018 Avenger ATI 27RBS
BriaBeck is offline   Reply With Quote
Old 04-20-2023, 12:16 AM   #273
Works good.
You all know you are replying to posts that were made back in 2016, right?
NavyLCDR is offline   Reply With Quote
Old 04-20-2023, 07:37 AM   #274
Thanks for the idea. I did not realize they made a in dash DVD/Stereo like this. I don't need outside speakers(waste in my book) so a zone 3 option is not required.
Curious as to what speakers you used.
Have not heard of Dual, will have to do some research.
2022 Rockwood 2511S
2018 F150 3.5 Crew Cab
Max Tow Package 1855 Lbs Payload
Husky CenterLine WDH
GolfingDave is offline   Reply With Quote
Old 04-20-2023, 09:10 PM   #275
BriaBeck's Avatar
For the interior I used some Rockford Fosgate 3-way 6" car speakers, and for the exterior I used MB Quart marine 6" 2-way speakers. The outdoor speakers are nice.
Brian & Becky
Old 05-17-2023, 03:23 PM   #276
Antenna
I have the irv 63,knock on wood, I've not experienced the frustrating issue I've read here.
I have another situation, I live in Canada,close to Buffalo N.Y.
Which means there are many good radio stations that are available. How ever the reception on this unit is terrible.
Static in all stations that should be clear.
I've removed the unit from cabinet,all wires,antenna are attached and in good shape.
Does any know where a potential diagram can be found that I may trace and hopefully identify a disconnect?
If not, with those who have a working unit how is the reception?
Thank you
Atk1d is offline   Reply With Quote
radio
