05-26-2015, 02:54 PM
#121
I have a 2016 Flagstaff 27VRL and the iVR unit exhibitis a buzzing noise when listening to the surround sound on TV Audio
05-26-2015, 05:52 PM
#122
I went through Todd and replaced my radio. As far as I know my dealer has no idea that I replaced the radio. In fact I'm still waiting for my dealer to call me with a fix.
2015 Flagstaff 26RLWS
2014 Chevy Silverado 4x4 5.3
[/SIGPIC]2015 Flagstaff 26RLWS Emerald
2014 Chevrolet 1500, 4 X 4, 5.3
73 nights in 2017
74 nights camped in 2016, 121 nights camped in 2015
05-27-2015, 10:45 AM
#123
My dealer and I tried dealing with forest river and they agree the radio had problems but wouldn't send a new unit until the dealer checked out the old one to make sure it was bad. That's a 2-1/2 hr. trip each way. I had my dealer contact Todd directly and Todd called me and he agreed that I had the vol problem and sent out a replacement to my home. I swapped out the unit and sent the bad one back to them.
05-28-2015, 07:30 PM
#124
tntbream,
If you have either an IRV33 or IRV66 radio then you can definitely go direct to Todd. He is a direct contact at Patrick Industries (the radio manufacturer) and all of the models (new designs) that were installed up until about a month ago are suspect. Todd only requires the model number, a brief description of the problem and your shipping address. He will ask for a credit card to guarantee that you will box up the faulty radio and send it back, but the new radio comes with a prepaid trip back.
I got my new radio within three days and it now works properly.
2015 Flagstaff Micro Lite 19FD
05-28-2015, 07:37 PM
#125
I got my replacement radio today and installed and it does the same thing. Also makes a little chirping noise occasionally when switching between sources. Guess I need to contact Todd again.
Jack and Jan
Nights camped 2014 - 8 | Nights camped 2015 - 23 | Nights camped 2016 - 24
2015 Ford Super Duty F350 > Blue Ox Swaypro WD Hitch > 2015 Rockwood Windjammer 3008W
05-31-2015, 11:58 AM
#126
Irv 66 stereo
Is anyone having a volume issue with stereo? Just picked up 2015 2703 and the minimum volume when listening to the stereo is to loud. There is no way you could sit have a meal with "soft" music in the background. Is there any way to adjust? Iv looked in the manual and tried online. Thanks
05-31-2015, 03:14 PM
#127
maddiesmom06,
Many of the IRV66 units that were installed at the factory have the volume issue (design flaw). Todd from Patrick Industries should be able to ship you one that works correctly. Look back through these posts for his direct telephone number.
05-31-2015, 06:00 PM
#128
We only get a couple stations the others are pure crackle. I thought it was the antenna, not anymore.
06-03-2015, 09:12 PM
#129
HI all, we received our new radio. It's now installed and works. The only thing we noticed is static on the AM Radio settings. Thanks to Todd E at Patrick Industries, no hassles.
Donna and Bob (retired USAF),
fur babies Casey (mix), Lucy and Loki (standard poodles)
had a 2015 Rockwood 8281 WS - traded for another brand.
2016 RAM 3500
06-06-2015, 11:48 AM
#130
Have the IRV 66 , it does the same thing after about 10 to 20 min on fm radio the speakers cut in and out.
Also the DVD player becomes unwatchable after 20 min or so, the sound also Cutts in and out. Does anyone know of a replacement system that will drop in place of the 66? Trailer is 2 weeks old.
06-29-2015, 05:25 PM
#131
just bought a 2015 Puma Unleased Toy hauler used it a week and now the power will not come on the IRV 66 checked the fuse its fine, power to tv and everything else fine. Not sure what else to check...Any Ideas?
06-29-2015, 05:45 PM
#132
Connector behind unit may have come undone. Remove trim ring, remove the four or so screws, slide unit out there are 3 wiring harnesses and a antenna jack and possibly red and white RCA banana jacks. Make sure all are in tight.
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
06-29-2015, 08:33 PM
#133
No power
Like uhduh has mentioned ,but I'm sure you checked the plugs in the back. If no no luck get ahold of Todd Eash, his number is in this theread earlier and let him know what's happening . We bought a 2015 3008 windjammer and replaced the original with an updated irv66. ( software) . I don't know how many Irv66 forest river has in their stock , but seems to be a software issue. Received our new one, installed it ,and no problems at all now. Todd is an excellent person to deal with. If you go through the dealer you bought the trailer from you might get an old stock replacement with the same issues.
Good luck.
06-29-2015, 08:47 PM
#134
You could try the remote to turn it on? It might be the power button itself. the radio is powered by the 12V system make sure you are checking fuses and not breakers. How are you checking fuses by eye or with volt meter? Better results with meter. If fuses are good pull unit out remove connector (red wire hot 12V not sure about ground wire could be black some times white). If hot call Todd if not you will have to trace both wires looking for open circuit. But check connectors to see if tight!!!! first!!!
Hensley Arrow
06-30-2015, 02:20 AM
#135
Engineer of Crazy Train
Has anyone tried usong the front HDMI port? Preferably for a Chromecast or Firestick? I tried the other day with a Chromecast and couldn't get signal to the television.
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183 (SOLD due to 2 years off work)
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 - 18
Come read my Camping Blogs
06-30-2015, 02:21 AM
#136
Also, I found that using digital coaxial sound from the television works better than analog. My wires were not hooked up right and tried both ways, and the digital is much clearer.
Locomotive Engineer
06-30-2015, 07:14 AM
#137
Radio
Get a new unit and put it in yourself. Very easy, they have had lots of problems with these Chinese Made Units.
07-01-2015, 01:38 AM
#138
iRV 66 Volume Problem Too
We just took our new 2016 Flagstaff V-Lite on its first shakedown cruise and discovered the volume problem, which was much too loud to suit our tastes, both on the HDMI input and on the radio setting. I will be contacting Todd Eash tomorrow. I am happy to know I am not the only one with this problem!
2016 Forest River Flagstaff V-Lite 30WRLIKS
2015 Ford F-150 4X4 3.5 L Ecoboost Engine
07-01-2015, 11:44 AM
#139
Todd Out Until July 7
I just called Todd Eash of QAV Patrick Industries about the iRV 66 volume problem. Unfortunately, he is off until July 7.
07-04-2015, 09:31 PM
#140
irv 66
My irv 66 pooped out. It's brand new and doesn't function at all. Light come in and that's it. Any one else in the same boat?
