Old 10-07-2016, 09:15 AM   #1
Icemaker install?
Anyone installed an Icemaker into the whirlpool refrigs' yet? I am thinking about installing one in my Hemi 286RL. any gotcha's or tips, help appreciated.
Robb
MORobb is offline   Reply With Quote
Old 10-07-2016, 09:56 AM   #2
AquaMan's Avatar
I installed one in my freezer drawer and it's a piece of cake! Takes a screwdriver and about 5 minutes.
2016 Georgetown 364TS
Nights Camped
2014 - 56
2015 - 41
2016 - 81
Old 10-10-2016, 07:48 AM   #3
I realize that the actual install of the ice-maker in the freezer is really easy. I was looking for information about running the water line, location of the solenoid and wiring. My Frig is in a slide.
Anyone completed this?
Robb
Old 10-10-2016, 09:39 AM   #4
Done it multiple times (always on top freezer units.) There is a single Whirlpool kit for pretty much every one of their units. If you aren't replacing a broken unit make sure you get the full kit with hoses, solenoid valve and icemaker. Should be between $50 and $100) You need access to the rear of the reefer and will need to install the solenoid valve to existing wiring and run a 1/4" nylon line up the back to the freezer section. There might already be a plastic fitting inserted in the back of the reefer for the hose to connect to.
Then you need to attach the 1/4" supply line to the other side of the solenoid valve.
2015 335DS
ScottBrownstein is online now   Reply With Quote
Old 10-10-2016, 12:00 PM   #5
AquaMan's Avatar
Robb
I see, mine already had the door water and ice but I wanted the freezer ice maker as well. That is what I thought you were talking about. Definitely would be a little more work without having the existing water line to the fridge.
Nights Camped
2014 - 56
2015 - 41
2016 - 81
