Old 09-04-2016, 08:31 PM   #1
Retired Trucker/43 years
Noneyerbusiness's Avatar
I'm aggravated .... Dometic Fridge errors
New 2017 Windjammer, Dometic DMR/DMC 7-Series .... is giving me the following error: "Overheating thermostat disconnected or The cooling unit has been over heated. Service is required."
Day before Labor Day, in the middle of Montana, no Dometic service center closer than Minot, and that will probably be closed tomorrow.
Removed 12v positive, and unplugged 110 for about 10 minutes to see if something would reset. Nope.
Help, anyone have a clue? (Before all my "stuff" thaws out)
2017 Windjammer 3029W
2006 Ford F-150
HD 7700# tow package
Noneyerbusiness is offline   Reply With Quote
Old 09-04-2016, 10:14 PM   #2
Maybe a solution ...
I read in another thread of the breaker being tripped on the LP flu that gives those errors, I checked that, seemed to be ok. Maybe a replacement sensor, (breaker), will solve the problem.
To be determined, I'm tempted to just short across it and see if the fridge works then ... but there's that warranty to be considered.
2006 Ford F-150
Old 09-04-2016, 10:26 PM   #3
Try this link. There is a Dometic tech on line at the moment.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting - Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - 6 speed - Tow Package
boondocking is offline   Reply With Quote
Old 09-04-2016, 10:51 PM   #4
Hey are you the FROG that I just met at Glacier NP? Youroo!!
Old 09-05-2016, 09:56 AM   #5
Head Rambler
When you checked the thermofuse (breaker), how did you check it?
If it were me, I'd jump across the thermofuse temporarily just long enough to see if the fridge would run.
There have been reports of those units reporting that the thermofuse was open when the problem was in the controls.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 09-05-2016, 01:07 PM   #6
Location: Full timer,,,at Lake Georgetown in central Texas for the winter.
Is this fridge in a slide? If so,,,,go outside,,,,,open the upper cover,,,,find the thermal-switch on the downstream side of the cooling fins, disconnect the two wires and jumper them together. The outside condenser cooling fan should come on. If it does, you more than likely have a defective thermal-switch, and I was told by the warranty folks at my Windjammer dealership that they've had problems with that switch. If it's open,,,,the unit will overheat and give you that code.
Grampa Jim is offline   Reply With Quote
Old 09-05-2016, 06:17 PM   #7
Yes sir, that's me ..... after we left, the fridge decided it didn't want to work .. we are in Minot now, will see the Forest River dealer here in the morning ...
2006 Ford F-150
Old 09-05-2016, 06:29 PM   #8
If it had Quit while at the C/G I could have loaned you a Cooler to make it Home,we have a 12V cooler that works well!! It would give us a reason to come over to Vandalia and eat at Bunkers! Good luck on the Frig repair! Youroo!!
Old 09-05-2016, 07:57 PM   #9
Have same fridge
I have the same fridge in my 2016 Columbus 385bh. I had problems from the time it was delivered with it not working continuously. Finally, a repairman replaced one of the tiny fuses with a larger one. It has worked fine all summer.
I think the fridge has a flawed design.
Debnc6 is offline   Reply With Quote
Old 09-06-2016, 04:21 AM   #10
Thanks Deb!
2006 Ford F-150
dometic, fridge
