Old 06-04-2013, 06:53 AM   #21
cpaulsen's Avatar
I use the 622 receiver. I ran a seperate cable to the bedroom from the splitter. I hook up one cable from my 1000.2 dish to the splitter....then one cable to the living room and the other to the bedroom......living room has the receiver. Pick up any channel you want from the receiver to the bedroom or living room. Just eliminated carrying 2 receivers.
cpaulsen is offline   Reply With Quote
Old 06-04-2013, 08:16 AM   #22
Iggy's Avatar
Originally Posted by kirkp View Post
The Boss TEMPORARILY decided she didn't want to take the plunge on a satellite system. That is until our maiden trip in our new TT. Rainy one day and cold/damp the next and what can only be described as really, really bad TV didn't help matters any. Then when the neighboring trailer plopped their satellite down it sealed the deal.
The unit they had was the vucube manual dish and when I looked into it I found that this same company makes the tailgater. I was surprised that it cost almost twice as much as the tailgater which is automatic. wondering if anyone knows what justifies the price difference? I saw that the tailgater is a dish only product while the vucube can be used on different services. Both are set up for one receiver. Anything else?
thanks,
Kirk
The Tailgater is only good for Dish Network.
You just need a coax feed. Power comes from the RV reciever 211K over the coax
The Vue Cube is good for Dish as well a DirecTV
THe Vue Cube a seperate power source
Iggy is online now   Reply With Quote
Old 06-04-2013, 08:18 AM   #23
My suspicion is that the ability to support DirecTV as well as Dish is what bumps up the price, but I really don't know. Given that Dish is the only one (currently) with pay-as-you-go, I would have a hard time justifying the extra $$$ for the cube. Also you can't get HDTV with DirecTV on the VuCube so I'd think that is another important deciding factor.
Old 06-04-2013, 08:30 AM   #24
What you're suggesting isn't supported with the Tailgater or VuCube. It also doesn't allow you to get HDTV on your second TV.
Also, a few technical details: You've got a separator (not splitter) between the 1000.2 and the receiver. You then have a splitter to the two TV's. (You should probably just connect the living room TV with HDMI.)
Old 06-04-2013, 07:05 PM   #25
Poppy94's Avatar
Originally Posted by BarryD0706 View Post
You can get a receiver that will support two TVs (eg, two different channels), or you can get a receiver for each TV. You're right: One receiver = One channel normally (except for the duals). (We can teach you later how to send one-channel of satellite to multiple TV's if you wanted to do that.)
ok barry, i got a winegard with my dish recvr from the house that does great in my TH. my uncle has a tailgater in his 5er. we both have satellite to the main television, but we have tried multiple ways to wire up the bedroom televisions to "look" at the same channel that the main television is looking at. not too worried about having it identical to the house where 1 receiver has 2 tvs watching separate channels, that'd be great, but for now if possible i'd like that, but i can also just deal with 2 tvs on same channel from 1 receiver. how is this done/accomplished? as stated, i've tried every kind of splitter and configuration i can think of. got a diagram or walk me through it? thanks.
Poppy94 is offline   Reply With Quote
Old 06-04-2013, 07:55 PM   #26
Let's start with multiple TVs on the same channel. You basically have two options.
1) If you have a way to pull new cable from place to place in your RV, the best option is to
pull new HDMI cable to each TV from the receiver and then use an HDMI splitter. You can find those on Amazon and other places. I'll give you some links if needed.
2) The second option makes use of the existing cable in your RV. There is an antenna amplifier (booster) control probably behind your living room TV. This already provides a splitter internally (and maybe externally) to send the over-the-air TV and "Park Cable" to all of your TV's. The Tailgater receiver, and probably yours, has a "modulator" output (labelled "TV Set Out"). Run a short coax cable from that receiver output to the "Park Cable" input on the antennae amplifier control. With this done, when the booster is off, the receiver modulated output will be available on channel 3 or 4 on all of the TVs. (You will probably have to have your TVs re-scan to find this "Cable" channel.) (What I really recommend you do is to use a coax "AB" switch so that you can select either the original "Park Cable" input or the "modulator output" into that "booster control". That way you don't lose function. Here's one such switch: Amazon AB Switch
This should get you started. Let me know if you need more details.
As for using your house "dual" receiver to get separate channels, the Tailgater doesn't support that. If you'll tell me the model of Winegard dish you use I can check to see if the dual receiver works with that.
Old 06-05-2013, 06:35 AM   #27
2604WS
First off, thanks to everyone for your help.
Barry, in reading your option 2, you mention Tailgater receiver so I am assuming your are talking about the Vip211K receiver? I'll have to look at things to see if I can find the booster you mention. Also wondering what function you might lose by not using the AB switch. Is this the ability to use the Park Cable function?
Kirk
Kirk
kirkp is offline   Reply With Quote
Old 06-05-2013, 07:18 AM   #28
Kirk
Kirk
Kirk,
Yes on 211k. Yes, if you disconnect the original "Park Cable" wire you wouldn't be able to use that unless you reconnect it again.
Old 06-05-2013, 12:46 PM   #29
2604WS
Barry, that's what I suspected you might mean. Talking to the Boss about it this morning. Since my tastes in TV viewing differ from her's (particularly when she isn't around) she wasn't sure if she wanted to be subjected to what I was watching when she went to bed. It got me to thinking whether you could install A/B switch in the bedroom so that that TV could be switched back to standard TV if she didn't want to watch satellite? My guess though is that based on your earlier post she (or should I say I) would have to scan channels again?
Kirk
Old 06-05-2013, 01:03 PM   #30
Kirk
It depends. Assuming you have your living room TV next to the receiver, it will be connected with HDMI. If she wants to switch to antenna for the other TV, just turn the booster back on and the "other" TVs will get that signal instead of Sat/Cable.
Chan 3/4 are the same on OTA and cable, so if your TV has a way to manually add channel 3 to the scan-found list, you'd have to do nothing. On
my TV, I can't do a manual add (Legend TV) but it does remember the Cable scan and OTA scans separately so all I have to do is switch from "Cable" to "Air" on the TV to go from Sat to Antennae.
Confused enough now? ;-)
