Old 06-21-2016, 01:29 PM   #1
Intermittent tv signal
Hi All, I have a 2015 flagstaff 27rlws and when we were out last weekend I raised the antenna , powered on the amplifier and scanned for channels. Everything worked great that day. The next morning the tv did not have any signal on any channel. Tried moving antenna to no avail and checked the amplifier and led was lit. I tried turning it off and on with no help. Kids were not happy. Any Ideas ?
PS when we got home and parked the trailer I tried it and we had tv again.
LindaNTom is offline   Reply With Quote
Old 06-21-2016, 01:59 PM   #2
Left Coast
Some times need to unplug tv for a couple minutes so it'll do a reset...
Old 06-21-2016, 02:58 PM   #3
Ok , Thanks I will try that next time out if it does it again.
Old 06-21-2016, 03:05 PM   #4
mark0224's Avatar
You might also want to check and see if the cable on the roof is tight, they sometimes loosen or wear out and need replacing.
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 06-21-2016, 04:23 PM   #5
Yes I checked the cable on the roof was tight. Forgot to mention when it lost signal both tvs did. So could the booster be flaky? Nor sure how to test it though.
Old 06-21-2016, 04:25 PM   #6
Flybob's Avatar
If your signals were marginal the first time, it is possible that weather/time of day could have pushed them past the usable point the second day.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 06-21-2016, 04:27 PM   #7
Left Coast
Sounds like loose connection....check the back of booster....and spitter if you can access it....I had to bore an access hole in side cupboard to reach mine
Sent from my XT1585 using Tapatalk
Old 06-21-2016, 04:27 PM   #8
Agreed. I've noticed that the channels I get always seem to come in better at night.
Iwritecode is offline   Reply With Quote
Old 06-21-2016, 04:32 PM   #9
Left Coast
You a ways from anywhere?
Old 06-21-2016, 05:23 PM   #10
B and B's Avatar
My money is on the LED lights interfering, they create RFI and kill reception. The 12 volt power source for the amplifier for the antenna is the same as the LED lights. I had it happen to use till FR replaced defective lights.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
