Old 10-23-2015, 05:00 PM   #11
I have the same issue with my'15 320RS. Works on shore power but not off batteries or when connected to tow vehicle.
ozarkcamper is offline   Reply With Quote
Old 10-23-2015, 05:28 PM   #12
Inverter has a fuse, check that. Also, most have a "pass through" when hooked to shore power, allowing 120v to pass through the inverter, since it's not needed to "invert" on that circuit, while on shore power. Sounds like an issue with either the GFIC, or fuse on the 12v side. Just a hunch.
Old 10-23-2015, 05:48 PM   #13
Thx, will ck. Fuse is ok. Where is the GFIC located for the fridge
Old 10-23-2015, 05:49 PM   #14
There is a lot of confusion on this forum regarding converters and inverters. While there are inverters that actually have a "pass through" mode, some units use inverters that do not offer this function. Xantrex offers both and a pass through unit in effect has an integral transfer switch...hence the pass through mode. FR uses Xantrex ProSine and ProWatt units. ProSine has a pass through (yellow unit) and ProWatt doesn't (black unit.) Georgetown uses ProWatt...no fuse, no pass through and a separate transfer switch.
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 10-23-2015, 06:34 PM   #15
Vince and Charlette's Avatar
Be sure the "Battery Control" is in the connect position. Also, as previously noted, the Xantrex has a reset on the GFCI outlet that controls the refrigerator. I found my finger didn't push the button in far enough to reset it. But it worked with the end of my pen.
2018 Berkshire 38A
Vince and Charlette is offline   Reply With Quote
Old 10-25-2015, 10:23 AM   #16
Senior member
inverter
check that all battery connections are tight. Mine worked on shore and generator but did not work with inverter. The ground battery cable was not tight and did not make good connection. Tighten the ground and all works great
efgsr47 is offline   Reply With Quote
Old 10-25-2015, 10:33 AM   #17
My bet is on the GFI since the remote switch is glowing green which indicates that the inverter is powered.
2015 335DS
Old 10-25-2015, 01:03 PM   #18
Senior member
inverter
Like I stated mine showed all green BUT ground cable from battery not holding strong direct contact. Need to be cleaned and tighten .
Old 10-25-2015, 02:35 PM   #19
I am sure it would depend on the inverter. A Xantrex would go into fault mode if the battery voltage dropped below acceptable and a loose ground would do that.
2015 335DS
fridge, inverter, power
