Old 10-23-2015, 07:54 AM   #1
Inverter for fridge is not powering
Hi. When I press the inverter switch button, the green light comes on, but I do not hear a "click" and the fridge does not power up. (Fridge is fine on shore power or generator.) Is there a breaker some where for the inverter? I could not feel one on it. It is mounted in the enclosed compartment above the propane tank on driver's side. Someone mentioned a bad relay? Thanks!
slmckel is offline   Reply With Quote
Old 10-23-2015, 08:04 AM   #2
Witch Doctor's Avatar
Don't know what invertor you have but check for a fuse on it.
Coachmen M/H
Concord
2018 / 300 DSC
Old 10-23-2015, 08:10 AM   #3
TURBS's Avatar
If the green light is coming on then it is obviously turning on.
Have you checked output voltage on the inverter?
TURBS
2008 duramax
2015 columbus 320RS
2015 camping "31 nights"
Old 10-23-2015, 08:12 AM   #4
Who Dares, Wins
doc73's Avatar
Or the battery... Could it be to low to supply the power for the fridge but enough to light it up.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 10-23-2015, 08:18 AM   #5
TURBS's Avatar
True
TURBS
2008 duramax
2015 columbus 320RS
Old 10-23-2015, 11:12 AM   #6
There is a GFI on the inverter itself where the frig is plugged it. I bet that it has popped. Mine did that. The remote switch will glow green since the inverter doesn't know the GFI is popped. Bet that is your problem.
2015 335DS
ScottBrownstein is online now   Reply With Quote
Old 10-23-2015, 12:00 PM   #7
TURBS's Avatar
Good catch.
TURBS
2008 duramax
2015 columbus 320RS
Old 10-23-2015, 01:10 PM   #8
Rodney & Patty
With mine, if I don't remember to turn it off before plugging in shore power, it will not work when I go back to the invertor. Each time this happens I have to pull the fuse for a few seconds with the switch off, reinstall the fuse and power it back up. It's a pain and happens often...
Working because we have to - camping because we want to.
2015 Salem Hemishere 337 BAR
2014 Ram 3500SRW Laramie 6.7 I6
rdenslow is offline   Reply With Quote
Old 10-23-2015, 01:18 PM   #9
That is possible depending on the model of inverter and the installation. Georgetown uses a Xantrex inverter and a Xantrex transfer switch dedicated to the reefer. I suppose it could trigger what you are describing but if I remember correctly, the Xantrex ProWatt inverters do not have an external fuse. In addition, if the fuse needed to be removed I would expect that the remote switch would not glow green in the interim.
2015 335DS
Old 10-23-2015, 02:27 PM   #10
14 CC 38CK's Avatar
I am gonna have to check mine because when I tried to use it this summer it didn't work either
14 CC 38CK is offline   Reply With Quote
fridge, inverter, power
