Old 08-26-2015, 09:42 PM   #11
I did hookup the tv to irv with an optical cable and it works. So the only thing that is not working is the front HDMI.
bvincent is offline   Reply With Quote
Old 08-27-2015, 12:06 AM   #12
RangeMaggotBob's Avatar
iRV66
My wife got a hold of Todd last Thursday. New unit sent out Friday. Received and installed Tuesday. Works great! Thank you Todd!
Dave & Theresa
2015 Forest River Rockwood Signature Series Ultra Lite 8289WS w/Diamond pkg.
2014 RAM CTD 6.7 Tradesman 4WD Auto Crew Cab Long Bed
Honda eu2000i generators
RangeMaggotBob is offline   Reply With Quote
Old 08-27-2015, 03:06 PM   #13
leefl's Avatar
I did notice that the replacement iRV66 display had the volume bar and spectrum analyzer displays twitching continuously, whereas the original one did respond properly to the audio input, albeit only at high volume.
I'm assuming that their (hack) fix for the audio cut-out, which was likely caused by a low input into the DSP in the first place, was to feed a fixed signal into the DSP control circuitry (or equivalent software hack), so that the DSP/equalizer now thinks that there is a constant audio source and doesn't switch off the pre-amp output.
I do wish they'd fixed it properly since the constantly twitching display is somewhat distracting
2015 Rockwood Signature UltraLite 8281WS
2016 Ford F-250 Lariat CrewCab, 4x4, 6.2L V8
leefl is offline   Reply With Quote
Old 08-27-2015, 03:08 PM   #14
Georgia Frog Rally 2018
aceinspp's Avatar
Who watches the display. No picture Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
aceinspp is online now   Reply With Quote
Old 08-28-2015, 05:44 PM   #15
leefl's Avatar
Heh. I don't want to watch it, that's the whole point. I'd rather it be off than jumping around pointlessly. I'm just easily distracted ;-)
Old 02-24-2018, 02:51 PM   #16
I have a new 2016 Rockwood and I'm having irv troubles, the TV volume does not work and the setup switch does nothing. I'm not sure if it is even wired up correctly. Does anyone have a wiring diagram.?
Crowell392 is online now   Reply With Quote
Old 02-24-2018, 04:33 PM   #17
Witch Doctor's Avatar
You might be able to find it on line, I think that Crutchfield electronics is the distributor, or you can call them, a very good and helpful company. Also the person above with the display problem, I would call them also.
Coachmen M/H
Concord
2018 / 300 DSC
Old 03-01-2018, 09:43 AM   #18
Bad sounding speakers
2014 freedom express 246rks-- My speakers are wimpy !!! Any suggestions for replacements ? They have to be light weight to mount in the same place overhead--very thin ceiling material..must sound better ! thanks
Nickrenfro is offline   Reply With Quote
Old 03-01-2018, 09:50 AM   #19
Not really but remember the depth when you buy them. I bought some and they wouldnt fit, so i sent them back...
Sent from my SM-N920V using Forest River Forums mobile app
Coachmen M/H
Concord
2018 / 300 DSC
Old 03-03-2018, 08:36 PM   #20
See my thread on RV Home theatre. I used Clarion coaxial 40 Watt RMS boat (shallow mount) speakers. Huge difference. Adding a sub woofer makes it even better. My thread has photos of the change out.
Netcomdude is offline   Reply With Quote
radio
