Originally Posted by bsowder
I have just joined this forum, please forgive me for not knowing how to use it but i have a problem with my control panel. My wife and I just purchased a new Forrest River 5th wheel and we can't get our panel to power up. it wont come on at all, any suggestions?
I hate to be 'that guy', but did you hold the power button on the panel for 2-5 seconds to get it to turn on? When you have the battery switch turned on and you are sure the ceiling lights and other 12v items are running from the battery or converter, is the red light on the panel power button illuminated? if the panel has power it will have a red light on the power button to turn it on.
If the answer is no, then try to hold in the reset button on the panel face with a thin paperclip. If that doesnt work, remove the 6 screws holding it to the wall and see if the Ethernet (RJ45) connector is attached securly. If that is good, then follow that wire down (or up) to the master relay box. Its the box that all the wires goes to from everything the panel controls. See if that RJ45 connector is connected correctly.
Lastly if you are to that point, you have access to the master relay/power box for the panel. You can see if you have 12v power to the input. And if you do have 12v to all connections that require it using the schematic pinout on the back of the cover, then you have something internal that is bad. If you dont have 12v, then i think you need to look further down the line, including the 12 fuses and any junction or fuse inline from that panel to the battery.
