Old 06-14-2019, 04:38 PM   #1
iRV in my Puma unleashed 2015
the I RV technologies radio in my camper comes on I can go through all functions but can't even get a single sound out of any of my speakers any ideas what I should look for?
R flinn is offline   Reply With Quote
Old 06-18-2019, 06:31 AM   #2
I had the same problem with my iRV 66. I took the thing apart too look for blown caps or anything indicating an issue. Found nothing. Put it back together and it worked. *shrug* It was very hot in my camper when I was trying to turn it on, and relatively cooler when I reinstalled it. So, it might be some type of thermal protection that I didn't notice. Try pulling the unit and replug all the connections, get the unit cooled down and try again.
2017 Ram 1500 Sport 5.7
2015 Flagstaff 27VRL
Riccochet is offline   Reply With Quote
Old 06-18-2019, 07:27 AM   #3
jeff64's Avatar
Those iRV 66s can be real frustrating.
Bob's Manuals - Download PDF Owner's Manuals
if you don't have a manual, you can get a .pdf and download or print one from that site.
As you read through it you should notice that the unit can be rebooted from the power switch, just like a laptop.
Top 3 buttons on the unit are speaker on/off buttons.
SRC button controls the source audio. ie. TV audio means the source is the RCA plugs on the back of your TV set connected by cable to iRV.
I think there is one that says DCC/OIC which is what is used if you connect the two with an optical cable.
This SRC setting could be your root cause
Hope that helps.
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
irv, puma
