Old 06-15-2015, 09:01 PM   #1
Lightbulb iRV Technologies
I have a Puma 23FB, with the iRV AM/FM/CD and DVD player. I did not get instructions when I bought the unit.
I put a DVD in and I can hear the sound, but no picture. The unit has HDMI and other inputs, but no outputs. My digital TV is connected to the 75 ohm antenna connection with the amplifier off. Nothing. No picture or sound on the TV.
What am I doing wrong?
Thanks.
johng4706 is offline   Reply With Quote
Old 06-15-2015, 10:35 PM   #2
RooVader's Avatar
What year is your camper? It should have hdmi or video out in the rear of the unit. If you cycle through the sources do you see r-hdmi or r-video?
XLR 24HFS -> Roo 21DK -> RPod 183g
2013 F150 FX4 EB
RooVader is offline   Reply With Quote
Old 06-15-2015, 10:57 PM   #3
jtstromsburg's Avatar
Try changing input on your TV to HDMI. It could have multiple HDMI inputs, so try each of them. Should be a button on the TV remote to cycle thru these, and maybe have to go to a menu first.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is online now   Reply With Quote
Old 06-16-2015, 02:25 PM   #4
RooVader,
The Puma 23FB is a 2015 model. The iRV is mounted above the dining table. There is no access to the back of the unit without taking the cabinet apart.
There are ONLY HDMI, Audio and Video IN. There is also a USB input and a slot for a SD card.
I ve hooked up plenty of stereo equipment over the years and there is always an OUTPUT. Nothing...
Old 06-16-2015, 02:31 PM   #5
RooVader's Avatar
All of the outputs on the iRV are on the back of the unit. You should have a cord somewhere that terminates at the tv location (it should be plugged into the tv).
On mine the output is not accessible either but the cord is coming out of the top of the cabinet where the iRV is mounted.
2013 F150 FX4 EB
Old 06-23-2015, 12:40 PM   #6
nikita's Avatar
On your tv remote there is a button called "input" - press it and select HDMI 1 - it should come up on tv, then press the button on top right of tv remote, "SCREEN SIZE" - pic THEATRE #2. Hope this helps.
Nikita
2011 Chevy Silverado Diesel 2500HD
2015 Sabre 33 RETS 5th Wheel
nikita is offline   Reply With Quote
