Old 07-12-2019, 07:15 AM   #1
IRV Technologies IRV33
I have an IRV33 radio DVD player that has failed. The new replacement is an IRV34, which I will have to purchase.
Does anyone have any experience or opinion on the IRV34 or recommendations on other replacements? I would appreciate any ideas or advice.
Bark is offline   Reply With Quote
Old 07-12-2019, 09:08 PM   #2
Newbie
My IRV33 unit never worked properly from day one. I finally purchased a Jensen unit from etrailer.com and am much happier. Seems to be a better quality unit.
How 'bout them Cowboys!
2015 Rockwood 2104S
2013 F150 4x4 EcoPuller
okiecowboy is offline   Reply With Quote
Old 07-13-2019, 08:48 PM   #3
IRV33
Hi okiecowboy,
Thank you for responding. I have been looking at a Jensen JWM60A. It looks like a good unit. My issue at this point consists of two concerns:
1)How much trouble did you have with the wiring connections changing from the IRV33 to the Jensen?
2) I am not sure if I have enough room to fit the Jensen in the space provided in my RV. Ia m sure you cannot answer that question and I will have to measure, measure and measure to be sure before I start tearing things up.
Old 07-14-2019, 04:10 PM   #4
Newbie
Hi okiecowboy,
The Jensen JWM60A is the exact unit I purchased. The wiring was no problem. I labeled the speaker wires as I unhooked from the old unit, then just wired them back up with closed end crimp connectors to the proper wires on the Jensen which are already labeled.
The Jensen unit is more rectangular shaped than the IRV unit. In my 2104S trailer I had to widen the mounting hole and then close in some of the gap at the top with a piece of wood trim. It looks pretty decent, and I'm no wood worker.
You will love this unit compared to the IRV33.
2015 Rockwood 2104S
irv
