Old 06-18-2014, 10:18 PM   #1
rce
Is block ice OK in a trailer fridge
Is it OK to travel with a large block of ice in a trailer fridge? (Camping without electricity scenario). Or would the ice be too heavy bouncing around inside the fridge? I guess I'm wanting to use the fridge like a cooler but afraid of breaking the "floor" of the fridge on rough roads.
2 door Dometec fridge in Surveyor ultralight
rce is offline   Reply With Quote
Old 06-18-2014, 10:24 PM   #2
dbarr's Avatar
My first trailer had an ice box. I'd put a 10 block in every 3 or 4 days but the tray it sat on drained to the outside.
'15 F150 Ecoboost Maxtow Scab '13 Freedom Exp. 233RBS
Days camped 2017-46, 2016 -56, 2015-33,
2014-47,
Years camping....52
dbarr is offline   Reply With Quote
Old 06-18-2014, 10:24 PM   #3
rce
Originally Posted by dbarr View Post
How are you going to drain the water?
Probably will find a large enough, strong enough plastic container to keep the ice, and water, in.
Old 06-18-2014, 10:25 PM   #4
SKnight's Avatar
I'd pad the floor with a couple of towels, but I suspect it might be OK. It really depends on how heavy a block of ice you carry.
Old 06-18-2014, 10:27 PM   #5
Your fridge should also run on gas. I don't see any way to use block ice in my fridge- just no room for it. Gas gets colder anyway in my fridge. And, like dbarr stated, the water puddling would be a problem.
Old 06-18-2014, 10:28 PM   #6
rce
Blocks I'm used to probably at least 20 pounds.
Old 06-18-2014, 10:31 PM   #7
dbarr's Avatar
Run gas. By the time you get the ice in there you won't have room for beer.
I'd use an ice chest first before turning my fridge into one.
2014-47,
Years camping....52
Old 06-18-2014, 10:32 PM   #8
rce
Fridge is pretty large. Could run it on propane but won't that drain the battery? I have a pretty basic battery.
Could just bring a cooler or two along I suppose but would prefer to keep a block of ice going in the fridge ...and the beer of course.
Old 06-18-2014, 10:32 PM   #9
dbarr's Avatar
oops...10lb block
2014-47,
Years camping....52
Old 06-18-2014, 10:38 PM   #10
rce
Maybe is not worth risking cracking the fridge floor with a 20 lb block bouncing around.
But if anyone has tried this would be nice to know results, good or bad!
fridge, trailer
