Old 02-28-2015, 10:05 PM   #11
jtrader's Avatar
I appreciate the offer but since I'm in Cincinnati shipping costs would make that pretty expensive. Thanks anyway.
My TT: 2013 Cherokee Grey Wolf 28BH
jtrader is offline   Reply With Quote
Old 02-28-2015, 10:08 PM   #12
Mojojojo's Avatar
Thanks was worth a shot... we got a Vissani from Home Depot fit ours with minimal trimming on the side.
My wife keeps saying I don't listen to her -Or something like that?...."My advice has no basis ,more reliable them my own meandering experience" Baz Luhrmann
2011 Sierra 355QBQ 1986 F350
Mojojojo is offline   Reply With Quote
Old 02-28-2015, 10:14 PM   #13
jtrader's Avatar
That's exactly the model I was looking at. How is it working out for you? Any tips on covering the access panel and roof vent? It seems that's the direction we're heading. After I replace this one I'll have a Norcold to tinker with and maybe come up with a work-around to patent LOL.
Old 02-28-2015, 10:20 PM   #14
jtrader's Avatar
Originally Posted by caper View Post
The board controls both side of the reefer (electric and propane) so the answer is no. It would be more economical to replace with a residential fridge then to replace with a gas/electric. You could also get a mobile repair person to look at the fridge on your site. No need to take to dealer. The repair person should be qualified to work on your style reefer. Is the reefer still under warranty? The appliances usually have a longer warranty then the trailer. If it is still under warranty see who the local repair person is for the Norcold fridge and have them do the warranty work.
No more warranty. 2 years ran out 6 months ago. Figures. Haven't decided to call the on-site repairmen yet. Not sure it's worth the investment when weighed against buying a residential unit.
Old 02-28-2015, 10:32 PM   #15
Mojojojo's Avatar
I leave tho top open and tape the vent holes as well as hard foam insulation, also a little soft foam top and bottom to keep drafts out
Old 02-28-2015, 10:35 PM   #16
jtrader's Avatar
Sounds like a plan. Getting it through the door will be a trick but I'm looking forward to getting rid of this Norcold money pit.
Old 02-28-2015, 10:39 PM   #17
Crockett's Avatar
a lamp cord hard wired direct to element is the way we in the industry test a cooling core. interrupt that circuit with a thermostat and now it switches on and off with a thermostat. i ran that 12 cuft for a while....sweet installl
edit: at 24" wide you might be pulling the entry door
Crockett is offline   Reply With Quote
Old 02-28-2015, 10:47 PM   #18
Mojojojo's Avatar
Not sure of your layout but two guys is probably a good idea ours went right in after a little shaving on the side it also helps to put it on something infront of the hole we used a milk crate on its side same height as our shelf for it.
Old 02-28-2015, 10:50 PM   #19
jtrader's Avatar
Or breaking out the hand files. Not sure yet.
Old 02-28-2015, 10:51 PM   #20
jtrader's Avatar
I'll have the manpower with the neighbor's help and I'm a pretty good woodworker so I see no problems. Depends on how long I feel like messing with the Norcold.
Did yours fit through your door very well? I think my door is barely 24" wide.
bypass, fridge, power
