06-10-2011, 05:53 AM
#21
Grumpy Old Member
Originally Posted by Dodge Guy
Is the Genesis 3.0 made by Concertone?
If it stopped working then chances are it is a Concertone!
Actually, I'm not sure if any of this stuff is made by Concertone. While I believe that Concertone is the importer of the products, the OEM is not identified.
A good example of this would be the Genesis appearing first in the wild with it's own labeling.
Chris Zazzara
2012 Windjammer 2008w
2020 RAM 1500
06-10-2011, 09:43 AM
#22
Villa Estate 392FLFB
it uses the same remote as the concertone but instead of the zx700 button it says 3.0 lol
One state/province at a time!
06-10-2011, 11:28 AM
#23
Owner - RVtronics
Find me a company that this is not true? VERY FEW American "Manufacturers" own factories anymore for a number of very good reasons BTW!
06-10-2011, 05:08 PM
#24
Grumpy Old Member
Agreed. The days of building stuff here in America are sadly gone, more than likely for good.
Chris Zazzara
2020 RAM 1500
08-16-2011, 02:21 PM
#25
Originally Posted by trudinator
We also have the Genesis 3.0 unit in our Rockwood 8293RKSS. Does anyone have any ideas about if you can get the audio from your TV to play through this thing?
I have a 2012 flagstaff 28ckss fifth wheel with the same problem it says to set the function to AU2 for the tv to play but it dosent did you ever get an answer to your question to get the tv to play.
08-16-2011, 02:35 PM
#26
Our TV is plugged into the AV2 input on the Concertone via a standard red\white RCA cable
You might want to make check:
1. That your TV's "audio out" has RCA cables plugged into it and\or
2. The concertone's input is not different than AU2...we had to cycle through the inputs till we found out AV2 worked
Ryan & Cortney
2012 Windjammer 3008w
08-16-2011, 04:32 PM
#27
Question for Bob--Why doesn't your company put there name on the units? I always thought that was odd.
2011 Flagstaff 8528RKWS
2015 Toyota Tundra
08-16-2011, 04:59 PM
#28
This look just like the Genesis in our new Signature Ultra Lite. I was able to get the surround sound working with the tv but nothing else. Tried the Bluetooth but couldn't get it to work. Couldn't get the setup button to work. The equilizer was set to off and could not get it to turn on. All Bass etc settings where at 0 and couldn't get them changed. The manuel was of no help. Hoping to spend more time on it when we camp in October.
RossandJan
2012 Rockwood 8314BSS
2006 Chevy 2500 HD 6.0 gas 4x4
Ross - Letter Carrier (retired 2011), Jan - YNC(retired 1996)
Nights Camped 2011 (8)
08-16-2011, 06:04 PM
#29
Inveterate Tinkerer
Our Genesis is pretty nice, so far have had a nice conversation with my techie nephew-in law that everyone could just sit back and speak, then have listened to several hours of pandora radio streamed from phone. I did rewire for HDMI to TV from DishHD reciever..but havent had time to really play with that yet. But it sounds good!! And I like the blue lites .
Randy
Randy and Cheryl
Sir Guinness-(Manchester Terrier)
2012 Windjammer 3065W
Chevy 2500HD Duramax/Allison
ProPride 3P
08-25-2011, 11:42 AM
#30
2007 WildCat 32QBBS
How is the Genesis working for everyone? Any failures that had to be replaced?
08-25-2011, 11:58 AM
#31
We have not used ours a lot at this time but so far we are very pleased with it.
08-25-2011, 12:00 PM
#32
Mine will be replaced. This is a Genesis 2 radio/DVD/CD. The buttons on the radio lock up, although the remote sometimes works while the unit is locked.
I usually have to pull the fuse to shut it off or I am unable to get it to work at all.
They're replacing it under warranty.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
08-25-2011, 07:48 PM
#33
Grumpy Old Member
The Genesis 3 that I originally posted about has been excellent. It's on almost all the time since I'm linked to satellite and enjoy the music. Nice piece of hardware.
Chris Zazzara
2020 RAM 1500
08-26-2011, 06:05 PM
#34
Ours has been awesome. Great sound....everything has worked fine after a minor problem with one of the buttons that was rectified by our dealer. The satellite radio is great! Love the surround sound.
2012 Rockwood 8293RKSS
08-26-2011, 06:19 PM
#35
im starting to get crackling and popping noises when playing games on the ps3 or xbox360, yet it never does it when watching a movie on either unit.. also have had it lock up sometimes but the remote still works...
08-29-2011, 06:20 PM
#36
I just received the Genesis 3.0 as a replacement to the ZX700. Everthing on the 700 worked but we had a video/audio sync issue about half way through a movie. The audio timing would lag the video by about 1 second. Very annoying. I could pause the movie and everything would work fine again.
New one seems to be OK. Haven't watched a full movie yet, so not sure if the sync issue will be with this one or not, but so far so good. I'll be checking it out this weekend.
08-29-2011, 11:40 PM
#37
2007 WildCat 32QBBS
So I received my Concertone 500 replacement today. The Genesis 3.0 works great. It was plug and play with the optional adapter harness. I linked it with my Blackberry to play music and make calls, very impressive when compared to the old 500. Only time will tell, but so far it's night and day difference since the old 500 didn't play B & C speakers, movies, CDs, ect.
If your wondering, the dealer where I recently bought my 07 WildCat covered it under warranty.
04-30-2012, 07:29 PM
#38
I PURCHASED A 2012 PUMA 25RS LAST OCTOBER.USED IT ONCE IN NOVEMBER TO MAKE SURE EVERYTHING WORKED.IT HAS A GENESIS GT 2.0 SYSTEM INSTALLED. IT WORKED FINE.TOOK IT OUT OF STORAGE AND TOOK IT ON A 2 DAY EXCURSION.WENT TO USE STEREO AND FOUND THE WHOLE UNIT TO BE INOPERABLE.THE POWER LIGHT DOES NOT COME ON.SCREEN IS TOTALY BLANK.PULLED UNIT OUT OF CABINET TO CHECK POWER.FOUND 12.9 VOLTS AT POWER CONNECTOR.I CAN ONLY ASSUME THE UNIT WAS NO GOOD AFTER 1 TRIP.DOES ANYBODY ELSE HAVE ANY THOUGHTS ON THIS?
04-30-2012, 07:42 PM
#39
Wanna Be Camper
My thoughts would be call your dealer and see about getting it replaced under warranty.
John & Deb
2011 Flagstaff V-Lite 30WRLS
05-11-2012, 05:53 PM
#40
We had our zx700 replaced with the Genesis 3.0. Our other unit played surround sound great on the tv. This new unit, no surround sound on tv. We do have surround sound for radio though, except the sub woofer isn't working right. Any help or thoughts about why no sound for tv? And I was able to adjust my sub woofer volume, but it still crackles real bad. Thanks for any help. Pics would be great too, if you have them.
David & Annamarie(Fatty & Harley)
2011 Rockwood windjammer(3065)
