03-24-2016, 02:04 PM
Is there a circuit breaker for this??
Out of the blue, my coach started acting up...
After swapping batteries, everything functions perfectly with the exception of a few items that went out completely.
The retractable door steps, awning motor, and rearview camera all decided to stop working all at the same time.
Now, with everything breaking at once, one would safely assume that there's a single switch or fuse for all of them. Well, I checked all of the above and everything is in order.
I have a 2012 Georgetown 351DS that we absolutely love, short of this new problem.
Thanks in advance for any advice.
“Some people spend an entire lifetime wondering if they made a difference in the world. But, the Marines don't have that problem.”
― Ronald Reagan
03-24-2016, 02:10 PM
When you swapped out the batteries could you have missed hooking up a small gage wire?
Did you put the cables on the batteries backwards?
2008 2500hd Duramax
2015 Columbus 320RS
2016 nights camped "0"
2015 nights camped "34"
03-24-2016, 02:53 PM
I very well might have now that you mention it. I'll have to try this today when I get home. Thank you!
― Ronald Reagan
2008 2500hd Duramax
2015 Columbus 320RS
I seriously think I didn't reverse the polarity as everything else in the coach functions as advertised.
― Ronald Reagan
03-24-2016, 03:03 PM
Ok
2008 2500hd Duramax
2015 Columbus 320RS
03-25-2016, 03:08 PM
TURBS, be nice..............
03-25-2016, 03:11 PM
Thought I flew low enough, guess not. [emoji87]
03-25-2016, 04:49 PM
Everything you mentioned that had stopped working is a DC voltage component so you have blown the 40 amp fuses in converter/inverter. Check those, you blew them if you hooked the batteries backward...........
03-25-2016, 07:58 PM
What dc fuses did you check? These items might be fused thru the coach 12 volt instead of the Rv side might want to check those fuses also
03-27-2016, 05:06 PM
Any resolution on this?
2008 2500hd Duramax
2015 Columbus 320RS
03-28-2016, 09:52 AM
Ford Idaho nailed it.
My coach is being stored at my in-laws house and it was my father-in-law who did me a favor and hooked up the batteries. Without checking how they're hooked up, I went in and checked everything out, seeing how everything worked just fine except those listed above.
After reading your posts, and while over their house for Easter this weekend, I cracked open the battery compartment and, sure enough, the two small gage wires were just dangling. As soon as I connected them to the positive lead, the stairs went up. Everything functions beautifully and learning has occurred. I now know exactly where to look (to include the 40 amp fuse) next time any one of those three things goes out.
Thanks to all of you for assisting with this. I love this forum!
― Ronald Reagan
03-28-2016, 10:00 AM
Very glad you got it working and that it was an easy fix.
Thank you for posting back with what the issue was, it may help someone else.
